Re: Firm brake pedal but crappy brakes ! ? ?
[Re: ahy]
#1210709
04/06/12 12:05 AM
04/06/12 12:05 AM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
The non power master has what looks like a one inch bore. I have some basic dial calipers, but they are not profesional grade. I also have 3 or 4 other master cylinders that I can try, but they are all for front disc/rear drum cars/trucks. One is a 1 1/16" and the others are one inch. Slamming on the pedal barely gets the front tires to skid in the dirt in my backyard. I blew compressed air through the passages of all my spare combination valves and they all seem clear and free flowing. I think that the one in the car should be okay too, since each corner moved a fair amount of fluid when I bled the brakes yesterday. I checked a website: www.imperialclub.com/repair/lit/films/274/index.html and while it is very old fashioned, there were some helpul tips there. Jeff
[Re: Jjs72D]
#1210712
04/06/12 11:30 AM
04/06/12 11:30 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If I am reading this right, you simply changed a master cylinder?
Or did you convert to manual brakes? Because in a manual setup the factory used more leverage than a power setup. If you do not duplicate this extra leverage then you will have a firm pedal with no braking.
[Re: Jjs72D]
#1210714
04/06/12 03:03 PM
04/06/12 03:03 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
you sure the bell crank wasn't to INCREASE leverage? i.e. more pedal travel for less master cylinder stroke? that would be an increase in leverage.
if you had this multiplication of effort before, but removed it and ended up with less leverage, AND went to a manual master, it could be your issue.
can you add the bellcrank back in if it indeed added leverage?
**Photobucket sucks**
[Re: Supercuda]
#1210718
04/06/12 07:12 PM
04/06/12 07:12 PM
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
I want to thank those that have lent a "brain" with my car problems. I agree that there are/were a series of mismatched components on this car. I'll give a history on the car.
*Originally a 4 wheel non power drum brake car. *I added the 11" a body front discs, Upper contol arms and power brakes including booster. This gave me the big bolt pattern. *I added a B body 8 3/4 axle with a Master Power 10.5" disc brake kit, bought from a swap meet. *The car had decent but not great braking at speeds over 20 mph. The low engine vacuum made stop and go driving unsafe, so I decided to try using the new master cylinder that came with the axle and brakes. The brakes bled out okay and the pedal was firm, but the stopping ability was terrible at any speed. *The fitting sizes and reserviors on the MP M/C are reversed from most other Mopar M/Cs I have seen. Usually the rearmost reservior serves the front brakes and has a smaller outlet fitting. Not so with the odd Master Power unit. *I switched the brake lines on the master back to front today. The braking improved a small amount, but the effort was tremendous to do it. *I pulled the master off and REmeasured. The bore looks to be 1 5/32" which I understand is HUGE for a non power unit. Also, there is a raised round nub at the mount, 1 1/2" in diameter similar to what a power brake M/C looks like. The M/C was in a bag and box when I bought the axle and brakes, but now I'm thinking that it could have been a switcheroo. *I cleaned and installed a non power disc master cylinder from a 75 Valiant. It has a bore size of one inch. The car stops better than it has since I have owned it. It isn't as good as a new car, but its good enough for now. Thank you all once more, Jeff
