Flywheel 2843212-1 #1209827
04/04/12 10:12 PM
04/04/12 10:12 PM
Philadelphia,PA
MoparJim Offline OP
MoparJim  Offline OP
Philadelphia,PA
Anyone familiar with this part number? Local guy has a new one for sale at a good price. I was wondering if this flywheel will work on a steel crank 340 with a stock '71 bellhousing.
PN 2843212-1 143 TEETH
Re: Flywheel 2843212-1 [Re: MoparJim] #1209828
04/05/12 12:20 PM
04/05/12 12:20 PM
dogdays Offline
dogdays  Offline
That number is a casting number and not a part number. I'm not sure if it's a 360-specific wheel or a neutral balanced wheel that was sometimes factory drilled for 360 use. A good number of them came behind 360s in trucks. It probably won't fit in your bellhousing because it is the larger diameter wheel, 143 teeth.
If I am correct in my guessing I'd suggest buying a new billet 130 tooth neutral balance flywheel. One is available from www.440source.com for $99.95. Keep in mind that the crank flange is the same for big and small blocks, so even though it's listed for 440 use it will also work on your steel crank 340.
http://store.440source.com/1045-Billet-Steel-Flywheel-New/productinfo/113-1014/
The statement "works for 10.5" clutch only" should really be works for 10.5/10.95" clutch only.
In the MOPAR world, the smaller 130T flywheel uses the 10.5" clutch but sometime in there they found a way to squeeze a 10.95" disk within the bolt pattern for a 10.5" pressure plate. If the clutch is listed as an 11" it most likely uses an 11" pressure plate that goes on the larger 143 tooth flywheel. This pressure plate uses a larger bolt circle to attach to the flywheel.
R.
Re: Flywheel 2843212-1 [Re: MoparJim] #1209829
04/05/12 12:45 PM
04/05/12 12:45 PM
The 143 tooth flywheels whrere the H.D. clutch option for the B-RB and 426 Street and race Hemi motors, not a option on the SB passenger cars. It will probally fit into a SB truck bell housing but not align with the starters on the SB passenger car bell housing, maybe so but I think not If it has several large (1.5 or bigger and 1/2 to 1 inch deep)diameter holes machined on the starter side of the flywheel it is a 360 flywheel IHTHs That casting number is early, probally late 1960s or very early 1970s
Re: Flywheel 2843212-1 [Re: Cab_Burge] #1209830
04/05/12 01:15 PM
04/05/12 01:15 PM
Philadelphia,PA
MoparJim Offline OP
MoparJim  Offline OP
Philadelphia,PA
Thanks for the information. Greatly appreciated.
