Pretty happy with my new Firm Feel Stage III. I also got their 11/16" tie rod kit. Plus, a new pitman arm and idler arm; alignment, etc. It was a tougher job than I thought, but ...
You are going to need room to drop the steering box in. Things are easier if you just move things out of the way (I dropped my header on the driver's side) . I originally thought I could put the box in from below, but there's too much "stuff" in the way. Plus if you are flat on your back in a garage or parking lot, it is a real pain.
