Crank Grind - Is a reblance necessary? #1203301
03/25/12 07:16 PM
03/25/12 07:16 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Would it be necessary to rebalance the rotating assembly after grinding the crank .010 on the rod and main journals? I would think mains would absolutely not matter and I would think the weight difference on the rod journals would be minimal.
And from what I understand the factory balance jobs aren't too close to begin with.
Re: Crank Grind - Is a reblance necessary? [Re: GTX MATT] #1203302
03/25/12 08:19 PM
03/25/12 08:19 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I agree w/ your opinion on all points.
It's Swifty! Swifty, you toad sucker!
Re: Crank Grind - Is a reblance necessary? [Re: zrxkawboy] #1203303
03/25/12 08:22 PM
03/25/12 08:22 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
how much metal is .010" cut on the journals? we're talking about .005" per side of the journal here. that's the thickness of a sheet of notebook paper.
so you're looking at a difference of grams, at which point, when you enter in the debate of how much oil to account for on the parts when calculating the balance numbers...I think you're well within the safe margin of error
**Photobucket sucks**
Re: Crank Grind - Is a reblance necessary? [Re: GTX MATT] #1203304
03/25/12 09:36 PM
03/25/12 09:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
thousands reground every day with no rebalance and live long healthy lives.
Re: Crank Grind - Is a reblance necessary? [Re: 70Cuda383] #1203305
03/25/12 10:01 PM
03/25/12 10:01 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
bearing thicker/crank thiner. should even out
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Crank Grind - Is a reblance necessary? [Re: GTX MATT] #1203306
03/25/12 11:47 PM
03/25/12 11:47 PM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
So, has the engine ever been apart before? Is this grinding the first on the crank or was it balanced when you put the engine together last? If you're pulling it for the first time and are going to grind on it, I would think you'd want it balanced just for your stated point above. If it was previously balanced, I'd agree with others that you're within tolerances - especially for street use.
Re: Crank Grind - Is a reblance necessary? [Re: ProStock1320] #1203307
03/26/12 02:18 AM
03/26/12 02:18 AM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
This is the first time its been apart, it was torn down because of low oil pressure with a valve train rattle at higher rpm and an intermittent complete loss of oil pressure. It looks like the complete loss of oil pressure was being caused by crap trapped against the screen on the pickup. The low oil pressure looks to have been a combo of bad cam bearings, and worn rod and main bearings. The crank looks ok, nothing inbeded and no deep gouges. However, it has a strange imperfection on some of the rod journals where it has a sort of ridge protruding upward, and the rod bearings were worn through to the copper where these ridges were.
Anyway, the car had like 20 lbs of pressure at hot idle and around 45 at 1000 rpm and up. The ridge wasn't bad at all, I'd gather it had about 100k on the clock. Its about $150 to grind a crank where I am so I figure I may as well go for it. This engine is going to be basically a stock HP street engine for daily driver type use, so nothing really fancy is required.
Re: Crank Grind - Is a reblance necessary? [Re: GTX MATT] #1203308
03/26/12 03:42 AM
03/26/12 03:42 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
This in itself isn't terrible depending on the weight of oil that you had in there. 5w30 with those numbers isn't bad. 20w50? Uhhh, time for some work.
Re: Crank Grind - Is a reblance necessary? [Re: GTX MATT] #1203309
03/26/12 10:04 AM
03/26/12 10:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It sounds like you are just going to do a rebearing rebuild on an engine with 100k miles on it ?
Re: Crank Grind - Is a reblance necessary? [Re: JohnRR] #1203310
03/26/12 10:38 AM
03/26/12 10:38 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
The factory engines werent "balanced", they just were "matched" when put together. Ive seen shade tree shop engines come appart with 3 different pistons, and a few with different brand bearings and other stuff miss matched and they hung together on the street, But a true balance is far more in depth than the factory.
I would think what your doing is fine for a Hone, bearing, rebuild.
