68-70 b body 8 3/4 axle brake lines #1203221
03/25/12 03:27 PM
03/25/12 03:27 PM
Just about to wrap up putting my rear axle assembly together and realized that my brake lines do not fit. My axle housing is the right length and it is unmodified. It measures 59 15/16 flange to flange. I bought a complete brake line kit from inline tube who I have had good luck with in the past. Anyways, I installed the brake tee / vent bolton the axle housing and then proceeded to put the axle lines on when I realized the right side was too short by a few inches to reach the block and the left line was too long . I assumed I had the wrong lines for a 68-70 b body, but now I am looking at pictures of original cars like mine and the brake tee is a lot closer the center of the axle housing than mine. Not sure what I have going on here, but these lines wont work with this housing, but they do look correct if my brake tee was in the right spot. Any thoughts on what is going on with my tee location or what lines I should order for this thing? Also, I think this may in fact throw off my rear brake hose too! AHHHH!
BTW, this is not the original axle housing from my car.
Re: 68-70 b body 8 3/4 axle brake lines [Re: ] #1203222
03/25/12 03:41 PM
03/25/12 03:41 PM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
I bought my rear brake line kit thru Year One. It was a stainless line and I assume the brand was In-Line Tube. Anyway, I have a '68 Charger with 8 3/4 and everything fit great. I put on both R and L side plus tee. My tee is located on drivers side positioned very close to center of axle housing.
Re: 68-70 b body 8 3/4 axle brake lines [Re: moparjo68] #1203223
03/25/12 03:48 PM
03/25/12 03:48 PM
I dont think the problem is with the lines themselves, I am looking through different pictures right now and it looks like the tee valve is positioned in a few different spots on these housings. I know I have the right length housing, so that isnt the problem. Look at the next two pictures I post, both of these are 1969 B body 8 3/4 axles with untouched tee valve locations.
Re: 68-70 b body 8 3/4 axle brake lines [Re: ] #1203224
03/25/12 03:50 PM
03/25/12 03:50 PM
2. Notice the tee valve is farther away fom the center of the housing.
Re: 68-70 b body 8 3/4 axle brake lines [Re: ] #1203225
03/25/12 03:56 PM
03/25/12 03:56 PM
moparjo68 Offline
moparjo68  Offline
My tee is like the first pic you posted. Its closer to the center than pic 2.
Re: 68-70 b body 8 3/4 axle brake lines [Re: ] #1203226
03/25/12 04:02 PM
03/25/12 04:02 PM
moparjo68 Offline
moparjo68  Offline
I'm guessing your setup is Pic #2 and the lines you purchased fit housing pic #1???
Re: 68-70 b body 8 3/4 axle brake lines [Re: moparjo68] #1203227
03/25/12 04:06 PM
03/25/12 04:06 PM
The lines I bought would fit the first picture, but I need a set for the location in the second picture. I guess I will get with inline tube and see what they can do. Has anybody else ever ran into this before? Does it cause any issues with rear hose length?
Re: 68-70 b body 8 3/4 axle brake lines [Re: moparjo68] #1203228
03/25/12 04:07 PM
03/25/12 04:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The location changed mid year 69.... Call them, they offer both styles..
Re: 68-70 b body 8 3/4 axle brake lines [Re: 1_WILD_RT] #1203229
03/25/12 04:12 PM
03/25/12 04:12 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just make some.Cheap and easy to do.Unless its a 100 point resto it will be close.Rocky
Chrysler Firepower
Re: 68-70 b body 8 3/4 axle brake lines [Re: 1_WILD_RT] #1203230
03/25/12 04:16 PM
03/25/12 04:16 PM
If I get the other lines from them, do I need to get a longer rear hose too?
Re: 68-70 b body 8 3/4 axle brake lines [Re: ] #1203231
03/25/12 04:53 PM
03/25/12 04:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't recall there being a longer hose.... Could be, if you get someone knowledgeable they should be able to tell you...
Re: 68-70 b body 8 3/4 axle brake lines [Re: 1_WILD_RT] #1203232
03/25/12 05:01 PM
03/25/12 05:01 PM
Ok, thanks for the help
Re: 68-70 b body 8 3/4 axle brake lines [Re: ] #1203233
03/25/12 09:22 PM
03/25/12 09:22 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The hose was probably the same, but the brass "tee" was different.
The first generation (pre 1070) tee is "Y" shaped and bolted to the housing parallel to the pinion.
The second generation (post 1969) tee is "V" shaped and bolted to the housing at a 45 degree angle toward the pinion.
