#1203221 - 03/25/12 01:27 PM 68-70 b body 8 3/4 axle brake lines
Just about to wrap up putting my rear axle assembly together and realized that my brake lines do not fit. My axle housing is the right length and it is unmodified. It measures 59 15/16 flange to flange. I bought a complete brake line kit from inline tube who I have had good luck with in the past. Anyways, I installed the brake tee / vent bolton the axle housing and then proceeded to put the axle lines on when I realized the right side was too short by a few inches to reach the block and the left line was too long . I assumed I had the wrong lines for a 68-70 b body, but now I am looking at pictures of original cars like mine and the brake tee is a lot closer the center of the axle housing than mine. Not sure what I have going on here, but these lines wont work with this housing, but they do look correct if my brake tee was in the right spot. Any thoughts on what is going on with my tee location or what lines I should order for this thing? Also, I think this may in fact throw off my rear brake hose too! AHHHH!
BTW, this is not the original axle housing from my car.
Edited by 1969HEMI (03/25/12 01:29 PM)
#1203222 - 03/25/12 01:41 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: ]
moparjo68 Offline
Loc: Sonoran desert, Arizona, USA
I bought my rear brake line kit thru Year One. It was a stainless line and I assume the brand was In-Line Tube. Anyway, I have a '68 Charger with 8 3/4 and everything fit great. I put on both R and L side plus tee. My tee is located on drivers side positioned very close to center of axle housing.
#1203223 - 03/25/12 01:48 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: moparjo68]
I dont think the problem is with the lines themselves, I am looking through different pictures right now and it looks like the tee valve is positioned in a few different spots on these housings. I know I have the right length housing, so that isnt the problem. Look at the next two pictures I post, both of these are 1969 B body 8 3/4 axles with untouched tee valve locations.
#1203224 - 03/25/12 01:50 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: ]
2. Notice the tee valve is farther away fom the center of the housing.
#1203225 - 03/25/12 01:56 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: ]
moparjo68 Offline
My tee is like the first pic you posted. Its closer to the center than pic 2.
#1203226 - 03/25/12 02:02 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: ]
moparjo68 Offline
I'm guessing your setup is Pic #2 and the lines you purchased fit housing pic #1???
#1203227 - 03/25/12 02:06 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: moparjo68]
The lines I bought would fit the first picture, but I need a set for the location in the second picture. I guess I will get with inline tube and see what they can do. Has anybody else ever ran into this before? Does it cause any issues with rear hose length?
#1203228 - 03/25/12 02:07 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: moparjo68]
1_WILD_RT Offline
Management Trainee
Loc: Today? Who Knows?
The location changed mid year 69.... Call them, they offer both styles..
#1203229 - 03/25/12 02:12 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: 1_WILD_RT]
therocks Offline
Its Lost
Loc: Niles , Ohio
Just make some.Cheap and easy to do.Unless its a 100 point resto it will be close.Rocky
Chrysler Firepower
#1203230 - 03/25/12 02:16 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: 1_WILD_RT]
If I get the other lines from them, do I need to get a longer rear hose too?
#1203231 - 03/25/12 02:53 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: ]
1_WILD_RT Offline
Management Trainee
I don't recall there being a longer hose.... Could be, if you get someone knowledgeable they should be able to tell you...
#1203232 - 03/25/12 03:01 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: 1_WILD_RT]
Ok, thanks for the help
#1203233 - 03/25/12 07:22 PM Re: 68-70 b body 8 3/4 axle brake lines [Re: ]
DoctorDiff Offline
Loc: Polson, MT
The hose was probably the same, but the brass "tee" was different.
The first generation (pre 1070) tee is "Y" shaped and bolted to the housing parallel to the pinion.
The second generation (post 1969) tee is "V" shaped and bolted to the housing at a 45 degree angle toward the pinion.
Contact info
25,700 Registered Members
196,768 Topics
340 6 BBL intake id ?
by moparx
01/20/19 12:02 PM
When you are bored in the Iowa winter. Mopar related!
by tboomer
01/20/19 10:57 AM
Best Way to Strip and Refinish Steel Rim
by floyd
01/20/19 10:49 AM
2002 24valve, I need a little more power
by RV2
01/20/19 10:44 AM
