How NOT to install a balancer. #1203026
03/25/12 11:35 AM
03/25/12 11:35 AM
Out West
408strokerdart Offline OP
Out West
Finally finding the time to post another picture or two from the engine tear down. I think the key would have liked to be aligned better before cranking down on the balancer. Second picture is my (brand new at the time expensive ATI balancer).
Re: How NOT to install a balancer. [Re: 408strokerdart] #1203027
03/25/12 11:55 AM
03/25/12 11:55 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Great pics. Amazing to see how far it actually went on with the key like that. Anyone have tips for avoiding this prblem on install?
Re: How NOT to install a balancer. [Re: Bill MeLater] #1203028
03/25/12 12:01 PM
03/25/12 12:01 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it's just a matter of being careful when you start the damper on (eyeball the end), i've seen this too many times. when in doubt remove the tool or bolt and check it. with a damper that fits tight you need to be even more careful as you can't tell all that well if it's mashing the key. as tight as some of these are it won't move the damper to align itself either if it's off a little
Re: How NOT to install a balancer. [Re: Bill MeLater] #1203029
03/25/12 12:06 PM
03/25/12 12:06 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i always hone the balancer so it just slides on with some drag. antiseize the snout, line up the keyway & press it on. never had that problem. i'd say that mess is fixable. seeya.
Re: How NOT to install a balancer. [Re: rickraw] #1203030
03/25/12 12:33 PM
03/25/12 12:33 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
probably was buzzed on with a impact - at least it looks like the crank keyway wasn't damaged.
I believe the hub can be changed on some of the ATI dampers if your concerned - Art is the guy to ask there.
Re: How NOT to install a balancer. [Re: SSAAHemiFan] #1203031
03/25/12 11:34 PM
03/25/12 11:34 PM
Out West
Out West
Not to worried about the parts....Damper hub can be dressed up, crank snout looks fine, key and lower gear will be a PITA to remove. These were new parts when assembled. I have put a small chamfer on the hub keyway before to make it easier to align just so this doesn't happen. Of coarse im not a professional though. LOL.
Re: How NOT to install a balancer. [Re: 408strokerdart] #1203032
03/25/12 11:38 PM
03/25/12 11:38 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Thats just wrong.
