New best and worst today! #1202906
03/25/12 12:19 AM
03/25/12 12:19 AM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Went to Test n Tune today and got a new best on first pass,7.16 @ 97.Then went 7.02 @ 98, 6.95 @ 99, 6.93 @ 99. I was getting a little greedy and shifted it at 6800 on the fifth pass a rod bolt or rod broke and put a whole in the oil pan. It was a old short block I had and I put some 360-2 heads and a Bullet roller cam in it. It was a .030 over 360 with a stock cast crank and rods. I have been looking at the stroker short blocks on Indy's web sight.Has anybody ever bought one and had any luck with it? Was thinking about getting a 422 or 440.The good thing about the longer stroke would be the lower RPMs and maybe longer life. THANKS......
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: New best and worst today! [Re: D-50] #1202907
03/25/12 12:24 AM
03/25/12 12:24 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
They always seem to run their hardest before they blow.
Sheldon
Re: New best and worst today! [Re: RUNCHARGER] #1202908
03/25/12 10:26 AM
03/25/12 10:26 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
sorry too hear the bad. good too hear the nice et's. your on this site quite abit and there's been way too many horor stories from the guys at indy. there's a couple of guys on this site than can get you what you need and have great customer service. i'm sure they will chime in.
Re: New best and worst today! [Re: Deepockets] #1202909
03/25/12 10:41 AM
03/25/12 10:41 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
nice new bests, sorry about the rod ,,,if it's not too far for you I would call Dan at Performance Only and have him build you a short block, I think you would be a lot happier in the end with the performance and customer service.
Re: New best and worst today! [Re: dartman366] #1202910
03/25/12 10:45 AM
03/25/12 10:45 AM
tboomer Offline
tboomer  Offline
Sorry to see the new best come along with destruction.. If you buy Indy stuff..buy from a dealer..Not Indy direct. Nothing but a-holes that answer the phone there..
Re: New best and worst today! [Re: D-50] #1202911
03/25/12 10:54 AM
03/25/12 10:54 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Ouch that is a bitter sweet day 4 sure.
I`ve been thru almost the exact thing myself.
Years ago ran a 10.08 1st day out with a cam change looking for my 1st "9".
Next time out the crank was in peices
Took 3yrs. to eclipse that 10.08 and go 9.97.
Good luck with whatever you choose to build
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: New best and worst today! [Re: RUNCHARGER] #1202912
03/25/12 10:55 AM
03/25/12 10:55 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sheldon
Seems true. Sorry to hear ya broke it. But hey now you get to build a new unit...
Coming soon!!!!
Re: New best and worst today! [Re: Mr.Yuck] #1202913
03/26/12 06:41 PM
03/26/12 06:41 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I was wondering since I was oiling the top half through the push rods and through the block that I run the bottom half dry.Do you think that might have caused the problem.
Re: New best and worst today! [Re: D-50] #1202914
04/28/12 07:51 PM
04/28/12 07:51 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Glenn here are some pics of your heads should be all done next week.
Re: New best and worst today! [Re: W5DART66] #1202915
04/28/12 07:53 PM
04/28/12 07:53 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
#2
Re: New best and worst today! [Re: W5DART66] #1202916
04/28/12 07:56 PM
04/28/12 07:56 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
#3
Re: New best and worst today! [Re: W5DART66] #1202917
04/28/12 07:57 PM
04/28/12 07:57 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
#4
Re: New best and worst today! [Re: W5DART66] #1202918
04/28/12 08:48 PM
04/28/12 08:48 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
You definitely have the right guy doing the heads, but what was the decision for the short block?
Re: New best and worst today! [Re: Scamp451] #1202919
04/30/12 06:46 PM
04/30/12 06:46 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thanks Brett,Looking forward to getting them back.
Scamp451 I am going with a 394 short block...Thanks
