Page 2 of 5 1 2 3 4 5
Re: Project Max Wedge [Re: 72N96RR] #1201940
03/24/12 11:44 AM
03/24/12 11:44 AM
NY
70440+6bbl Offline OP
NY
Sweet, thanks Jim!
Re: Project Max Wedge [Re: 70440+6bbl] #1201941
03/24/12 11:48 AM
03/24/12 11:48 AM
NY
NY
I bought a NOS passenger side inner fender well and a nice used driver's side to replace the cut-up originals as I thought that would be the easiest way to get the work done, but Joey's feeling is to keep as much OEM metal as possible. Since the factory inner wells had zero rust anywhere, he set about making a set of patch sections for them. Here is the passenger side in progress...
It is not permanently attached yet as he removed the upper cowl and middle firewall section in order to replace them with nice California parts. These sections were rusted due to nasty mice or rats making nests.
Re: Project Max Wedge [Re: 70440+6bbl] #1201942
03/24/12 11:53 AM
03/24/12 11:53 AM
NY
NY
Other side...
Re: Project Max Wedge [Re: 70440+6bbl] #1201943
03/24/12 11:54 AM
03/24/12 11:54 AM
NY
NY
The right shock tower also was smashed in for header clearance, here it is all fixed now.
Re: Project Max Wedge [Re: 70440+6bbl] #1201944
03/24/12 11:58 AM
03/24/12 11:58 AM
NY
NY
Nasty vermin damage
Re: Project Max Wedge [Re: 70440+6bbl] #1201945
03/24/12 11:59 AM
03/24/12 11:59 AM
NY
NY
Underlying damage seen once upper cowl was removed...
Re: Project Max Wedge [Re: 70440+6bbl] #1201946
03/24/12 12:00 PM
03/24/12 12:00 PM
NY
NY
And the cure, nice California metal
Re: Project Max Wedge [Re: 70440+6bbl] #1201947
03/24/12 12:02 PM
03/24/12 12:02 PM
NY
NY
I drilled it all apart prior to bringing it to Joey's place in MI. Using a Blair spot weld cutter and a few hours, it all came apart.
Re: Project Max Wedge [Re: 70440+6bbl] #1201948
03/24/12 12:03 PM
03/24/12 12:03 PM
NY
NY
This firewall section will donate some parts to the cause as well.
Re: Project Max Wedge [Re: 70440+6bbl] #1201949
03/24/12 12:07 PM
03/24/12 12:07 PM
NY
NY
The fellow that bought the car in '77 thought of a great idea in order to prevent gas thieves from getting any of his fuel. He flipped the gas filler neck around and cut a hole in the filler tube cover. This made it necessary to fill the tank with the trunk open, but made for more work during the metal restoration phase
Re: Project Max Wedge [Re: 70440+6bbl] #1201950
03/24/12 12:08 PM
03/24/12 12:08 PM
NY
NY
The cure...
Re: Project Max Wedge [Re: 70440+6bbl] #1201951
03/24/12 12:11 PM
03/24/12 12:11 PM
NY
NY
Just to show off some of Joey's skills, here is an aluminum hood and scoop that he made for a customer that is restoring a '63 lightweight car. It fits my car perfectly!
Where is that winning lottery ticket?
Re: Project Max Wedge [Re: 70440+6bbl] #1201952
03/24/12 12:12 PM
03/24/12 12:12 PM
NY
NY
The bottom side...
Re: Project Max Wedge [Re: 70440+6bbl] #1201953
03/24/12 12:14 PM
03/24/12 12:14 PM
NY
NY
Here it is, test fitted on my car. Also shown is the aluminum front bumper and lower valance that he made. I believe he will be making the fenders next.
Re: Project Max Wedge [Re: 70440+6bbl] #1201954
03/24/12 12:17 PM
03/24/12 12:17 PM
NY
NY
A picture of the future powerhouse
I started out by finding a '63 426 TMP block (still need a correct TMPHC block, anyone?), then ended up with several intakes and heads before I finally found near perfect, uncut examples (NOT an easy task with 50 year old race parts). I bought most everything needed for the engine and tried to get the closest dates that I could find. Probably the hardest original MW parts to find would be the oilpan, carbs and block.
Re: Project Max Wedge [Re: 70440+6bbl] #1201955
03/24/12 02:11 PM
03/24/12 02:11 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
That hood is sweeeet!!! As is the powerplant...Great car...!!!! Im miss my Vert!!!!
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Project Max Wedge [Re: 72N96RR] #1201956
03/24/12 08:23 PM
03/24/12 08:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Looks to be coming nicely. Ron
Re: Project Max Wedge [Re: 70440+6bbl] #1201957
03/25/12 01:38 AM
03/25/12 01:38 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
its about time you start posting pics of the maxie on here! looks like its coming along
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Project Max Wedge [Re: mopars_1] #1201958
03/25/12 09:41 PM
03/25/12 09:41 PM
NY
NY
Hmmm, I wonder if this was ever approved by the NHRA?
FYI- that is a leather waist belt
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Project Max Wedge [Re: 70440+6bbl] #1201959
03/25/12 10:43 PM
03/25/12 10:43 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Looks good James!
It's going to be a very nice car when complete.
Ed
