Help with gen 3 fuel #1199976
03/19/12 11:39 PM
03/19/12 11:39 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
Are u guys running a full return style efi fuel system? Tank - pump-Y- rails-regulator- to tank
Re: Help with gen 3 fuel [Re: W9 Dart] #1199977
03/20/12 12:12 AM
03/20/12 12:12 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
My procharger kit came with a boost a pump box. It gives more volts to the pump under boost.
My SRT challenger is just shy of 500rwhp. If your going much higher I'd look at magnafuel and a boost reference regulator.
Re: Help with gen 3 fuel [Re: FastmOp] #1199978
03/20/12 12:21 AM
03/20/12 12:21 AM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I have my components already I just wanted to know what style of system to run? None of the high hp car lx, ly, keeps etc are running a full return system.
Re: Help with gen 3 fuel [Re: W9 Dart] #1199979
03/21/12 03:02 PM
03/21/12 03:02 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
My higher HP customers are running dual or triple in tank pumps and larger feed line, with the factory (in tank sorta) return system.
I'm sure a return line/system from the fuel rails would work fine also.
