Re: Help me pick out a shifter!
[Re: Locomotion]
#1198975
06/11/12 06:53 PM
06/11/12 06:53 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Got my first PPP a few months back from John Holt race cars on here and have not used it yet but love the look and feel. I got the cheaper one, manual shift all the brackets, cable etc. was a touch over 300$
One day I will have something cool here.
[Re: ProStDodge]
#1198979
06/11/12 10:18 PM
06/11/12 10:18 PM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Tranzact pro tree transbrake valve body w/ clean neutral, TA Cheetah shifter.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Locomotion]
#1198983
06/12/12 07:08 AM
06/12/12 07:08 AM
Posts: 846 Long Island, NY
Cudafied
Long Island, NY
Does anyone know of a reverse manual valve body shifter w/reverse lock-out that can be shifted from high gear into neutral?
I've been doing it with a Hurst 1/4 stick, but it's about time I change to something better. I just like to go into neutral past the finish line.
PPP shifter Look at picture
[Re: Cudafied]
#1198984
06/12/12 09:06 AM
06/12/12 09:06 AM
Posts: 5,894 Florida
Locomotion
Hmmmm. Unless someone knows for sure, I'll have to call them. But it looks like it may require a special valve body. If not, it would need a pretty complicated and strong spring-loaded mechanism inside to actually shift the trans into neutral when the shifter is pulled all the way back.
[Re: Locomotion]
#1198985
06/12/12 09:15 AM
06/12/12 09:15 AM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
Yes, you do need a special valve body that has a clean neutral after high gear.
[Re: moparguy7074]
#1198987
06/13/12 06:45 AM
06/13/12 06:45 AM
Cudafied
Long Island, NY
The clean neutral valve body is a transbrake valve body. If you look at the picture you'll notice neutral & reverse are lined up, to get into reverse move the shifter to neutral then push down the silver button on the top of the handle and squeeze the lever at the same time this will trigger the micro switch in the shifter to activate reverse.
