Making my own diaper #1198747
03/18/12 02:06 AM
03/18/12 02:06 AM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
I decided to make my own diaper.
There’s no way I can go wrong since there are no specifications or even suggestions from NHRA
as to what qualifies an acceptable diaper.
The one I bought was a real joke using a nylon type material that easy to melt.
The straps were no better and above all the catches PLASTIC just like on a child’s nap sack.
The only positive thing that can be said about it was the fit was acceptable.
That did not take very much as there is only one end stitched to conform to the pan.
A yard of material at a local source at a cost of 9.00 that is much better quality and not nylon based. .
That is enough to material make three diapers. It is used on boats for seating.
To replace the plastic catches and nylon straps I ordered 6 canvas belts with D rings at 2.95 each from EBay.
So about 21.00 is the cost for all necessary materials.
I will take it to be stitched like the old one not sure of the cost.
Only part stitched to form is the front end which gets a pocket 7” deep and 9”wide.
The only place it need be stitched is to hold the straps to the diaper.
picture is of my old one
home of the
Sox and Martin Hemi Duster
Re: Making my own diaper [Re: HEMIFRED] #1198748
03/18/12 09:49 AM
03/18/12 09:49 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Good thread. MOre pics as you go.
Re: Making my own diaper [Re: Hot 340] #1198749
03/18/12 10:50 AM
03/18/12 10:50 AM
PA
moparacer Offline
moparacer  Offline
PA
I was going to make one for mine also untill I seen what you can buy one for.
I had J&J make one for my car and other then a couple little modifications it really fits great.
For ballistic material and $150 cost wasn't worth the headache making one myself.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Making my own diaper [Re: HEMIFRED] #1198750
03/18/12 10:56 AM
03/18/12 10:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I guess I better get my industrial sewing machine
back up and running... I re-did the interior in my
boat a few years ago so I would think I can make a diaper
Re: Making my own diaper [Re: MR_P_BODY] #1198751
03/18/12 11:00 AM
03/18/12 11:00 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Fred, at your age...that will be the first of many diapers you will have to change....
Re: Making my own diaper [Re: joshking440] #1198752
03/18/12 11:38 AM
03/18/12 11:38 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Josh,you been hangin out at the other 2 sites too much Even you can be a dipstick once in a while
Fred,the material you purchased,is it fireproof??Is the ballistic material the "other guys " use fireproof?
I was waiting for you to calm down and come up with a solution for theses new rules with no rules
I do believe that the diaper should wrap around the outside of the oil lines where they enter the oil pan and come off the oil pump and only have a hole for the centerlink.I still have some expences that are in front of the diaper on the "LIST"
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Making my own diaper [Re: hemi-itis] #1198753
03/18/12 12:03 PM
03/18/12 12:03 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
OK, so Fred will be wearing a fireproof diaper. You can never be too safe.
Yeah, it's got a smallblock.
Re: Making my own diaper [Re: 340B5] #1198754
03/18/12 01:46 PM
03/18/12 01:46 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I didn't know Fred liked Meskin food? Gotta watch those habanero peppers.
Floyd Lippencott IV
Re: Making my own diaper [Re: HEMIFRED] #1198755
03/18/12 02:08 PM
03/18/12 02:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Fred... do you have a pic of the material you plan on
using... maybe a source for it also.... I'm going to
look into making one also... thanks
Re: Making my own diaper [Re: hemi-itis] #1198756
03/18/12 02:36 PM
03/18/12 02:36 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Coming from you... the king internet stalker, that holds little to no substance....
Re: Making my own diaper [Re: HEMIFRED] #1198757
03/18/12 07:18 PM
03/18/12 07:18 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
I canceled the belts due to higher cost of shippping and instead ordered 30 1" stainlesss steel "D" rings at a cost of 17.00. The revised total cost for material to make two diapers 25.00 .Before I figured one cost to 21.00 but the belts were only 2.95 but another 3.50 to ship.
the material I bought is nothing special other than just a bit stiffer and stronger. There were many others that would have worked out fine. I did not look for fire retardant type.
here's a pic new on the left
Re: Making my own diaper [Re: HEMIFRED] #1198758
03/18/12 07:22 PM
03/18/12 07:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Pic didnt work... have a pic of the material you used
Re: Making my own diaper [Re: MR_P_BODY] #1198759
03/18/12 07:27 PM
03/18/12 07:27 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
here's a close up
home of the
Re: Making my own diaper [Re: HEMIFRED] #1198760
03/18/12 07:30 PM
03/18/12 07:30 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
the only stitching up front is a pocket as wide as the pan and about 4" deep. this is real basic
home of the
Re: Making my own diaper [Re: HEMIFRED] #1198761
03/18/12 07:33 PM
03/18/12 07:33 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
inside stitch work
home of the
Re: Making my own diaper [Re: HEMIFRED] #1198762
03/18/12 07:38 PM
03/18/12 07:38 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
I neglected to mention that in leiu of the belts I decided to use some old 1" tie down straps.
the rear has a similar pocket but only 2" deep.
this combined with the one in the front do a decent job of having the diaper conform to the pan so it sits inside it.
home of the
Re: Making my own diaper [Re: HEMIFRED] #1198763
03/18/12 07:42 PM
03/18/12 07:42 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
inside stitching rear pocket
home of the
Re: Making my own diaper [Re: HEMIFRED] #1198764
03/18/12 07:46 PM
03/18/12 07:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
u can call it depends #2 Freddy
Re: Making my own diaper [Re: HEMIFRED] #1198765
03/18/12 08:07 PM
03/18/12 08:07 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
as far as fit like I said before the old was ok and here's a better pic you can see how it covered the dual lines very nicely.
I should note here that my Olson pan is only about 5" deep in front and 6.5" in the rear. The sides are about 8" in the front and taper up to 10" at the rear. the same exact pattern as mine can be used with deeper pans just account for the longer sides. If the side panels are too tall they will tend to fall over and away from the block. My guess is stopping at the freeze plug is high enough
home of the
Re: Making my own diaper [Re: HEMIFRED] #1198766
03/18/12 08:17 PM
03/18/12 08:17 PM
SOUTH JERSEY
HEMIFRED Offline OP
HEMIFRED  Offline OP
SOUTH JERSEY
forgot to show the tabs that attach it in this case the header bolts were used. I have not attempted to find them for sale as I have one set and will look later.
home of the
