727 - Valve Body Removal #1198129
03/16/12 09:59 PM
03/16/12 09:59 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
Any tips or tricks to removing the valve body in a 727 lock up trans.
I am going to replace the shifter shaft seal.
Thanks,
Jason
Re: 727 - Valve Body Removal [Re: CUDAJAS] #1198130
03/17/12 10:33 AM
03/17/12 10:33 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I changed my seal without having to drop the valve body.
K-D makes a tool for this
http://www.costplustools.com/Atec-T-1031...er-_p_9289.html
1MYTGTX
Re: 727 - Valve Body Removal [Re: 1MYTGTX] #1198131
03/17/12 11:40 AM
03/17/12 11:40 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just carefully pry the old seal out then gently tap a new one in.
Re: 727 - Valve Body Removal [Re: CUDAJAS] #1198132
03/17/12 04:45 PM
03/17/12 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're going to remove the VB, put it in Park and turn the driveshaft until it clicks into park...this will make the park rod easier to remove.
Re: 727 - Valve Body Removal [Re: 1MYTGTX] #1198133
03/19/12 01:17 PM
03/19/12 01:17 PM
CUDAJAS Offline OP
CUDAJAS  Offline OP
Thanks guys,
I have seen the tool, but I need to change the fluid and filter anyway, so no big deal on dropping the vb.
Jason
