Page 1 of 3 1 2 3
400 BB Mopar dyno test part 2 #1197317
03/15/12 01:30 AM
03/15/12 01:30 AM
SoCal
Brian Hafliger Offline OP
SoCal
I wanted to try the Victor std. port heads on this 400 with a cam change and bump in compression to see how much power we can get out of a somewhat budget type build.
What I didn't know is that Edelbrock has changed their Victor heads! A new heart shaped chamber and smaller more restrictive intake bowls.
I was worried about them performing well since the intake ports are down on flow compared to the older castings.
I was very happy to see a pretty decent amount of power for a pump gas budget deal. No porting was done, on anything.
New spec's are:
New Victor heads, OOTB with our valve job and small chamber cut.
Compression at 10.6:1.
Hughes 1.7 rockers (VERY nice rockers by the way!!).
Tried both the rpm intake, and victor intake which made the best avg. power over the rpm!
Holley TRUE Ultra 950HP
Still used the 1 7/8 TTI headers, same bottom end as prior but changed the cam to a custom grind: 255-260 @ .050 on a 110lca and .648/.638 gross lift.
And all the power came in at a very respectable rpm IMO.
I would highly recommend some porting on these heads to make the best of them, but like I said it was a budget type build on pump gas.
Still, if you look at the TQ and HP curves it's making really good avg. power AND torque.
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197318
03/15/12 01:31 AM
03/15/12 01:31 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197319
03/15/12 01:32 AM
03/15/12 01:32 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197320
03/15/12 01:32 AM
03/15/12 01:32 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197321
03/15/12 01:33 AM
03/15/12 01:33 AM
SoCal
SoCal
Difference between the 2 builds...
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197322
03/15/12 01:36 AM
03/15/12 01:36 AM
SoCal
SoCal
pic1
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197323
03/15/12 01:47 AM
03/15/12 01:47 AM
SoCal
SoCal
2
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197324
03/15/12 01:49 AM
03/15/12 01:49 AM
SoCal
SoCal
3
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197325
03/15/12 01:50 AM
03/15/12 01:50 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197326
03/15/12 01:50 AM
03/15/12 01:50 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197327
03/15/12 01:51 AM
03/15/12 01:51 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197328
03/15/12 01:51 AM
03/15/12 01:51 AM
SoCal
SoCal
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197329
03/15/12 01:52 AM
03/15/12 01:52 AM
SoCal
SoCal
8
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197330
03/15/12 01:53 AM
03/15/12 01:53 AM
SoCal
SoCal
9
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197331
03/15/12 01:55 AM
03/15/12 01:55 AM
SoCal
SoCal
10
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197332
03/15/12 01:56 AM
03/15/12 01:56 AM
SoCal
SoCal
11
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197333
03/15/12 01:57 AM
03/15/12 01:57 AM
SoCal
SoCal
12
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197334
03/15/12 02:29 AM
03/15/12 02:29 AM
Cab_Burge Online work
Cab_Burge  Online Work
What do you think of reducing the oil pressure some? What weight and type oil and oil temps? Is the AFR going fat on one side or is there something goofy on the chart? It is amazing (and satifying) sometimes what results we can get experimenting
Re: 400 BB Mopar dyno test part 2 [Re: Cab_Burge] #1197335
03/15/12 04:36 AM
03/15/12 04:36 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Are those rockers a newer design from Hughes ?
They look SWEET !!!
did the victor chamber change as far as cc's OOTB ?
I could be way wrong ..... but is there a lot more in it? with that high lift cam and 1.7 rockers + victors....should be 550+ hp ?
Just curious--im not an engine builder
Re: 400 BB Mopar dyno test part 2 [Re: Brian Hafliger] #1197336
03/15/12 08:25 AM
03/15/12 08:25 AM
gregsdart Offline
gregsdart  Offline
Thanks for the post, Brian, love to read this stuff. Any chance you might try stealth heads on this combo?
Page 1 of 3 1 2 3
