rear gear ratio - tag missing #1192662
03/07/12 12:37 AM
03/07/12 12:37 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
my 84 dodge swb van rear end tag is missing how can i find out what gears are in it i tried google but no luck
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: rear gear ratio - tag missing [Re: gogo318] #1192663
03/07/12 12:55 AM
03/07/12 12:55 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
You jack up the rear, put the trans in neutral and turn a tire one rotation and count how many times the driveshaft turns. If you have a sure grip, it's pretty stratight forward.
For instance if you the driveshaft rotates 3.55 turns, you have a 3.55 to 1 ratio.
With an open rear end you need to have someone hold one of the tires and rotate the other one two revolutions while counting how many times the driveshfaft goes around. You can do this by yourself by just jacking up one wheel.
Here is a page with more information. http://www.jedi.com/obiwan/jeep/misc/gearratio.html
Re: rear gear ratio - tag missing [Re: NicksGarage] #1192664
03/07/12 03:42 AM
03/07/12 03:42 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
3.21s or 3.55s
I am truckless..
Re: rear gear ratio - tag missing [Re: gogo318] #1192665
03/07/12 03:58 AM
03/07/12 03:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If you have all of those vehicles listed in your post, you're probably skilled enough to pull the diff cover to see inside. It probably needs a fluid change by now anyway. THAT way you know the ratio for certain.
Re: rear gear ratio - tag missing [Re: Kern Dog] #1192666
03/08/12 01:21 AM
03/08/12 01:21 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
actually it has fresh fluid thats how the tag came up missing (oops) i also know its stamped in the ring gear but tring to not pull the cover just to find out also im no expert on mopars thats why i signed on to this great forum so i can pick the experts brains and i do have the cars listed but none are restored there just drivers (one day..... ) any ways i need to know the gearing as stock so i can figure what gears i should consider to get a better launch its running 15.1s now with a blown power valve ( didnt have time to fix before the track opened)
Re: rear gear ratio - tag missing [Re: gogo318] #1192667
03/08/12 01:55 AM
03/08/12 01:55 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Just a helpful tip..... PLEASE PLEASE use some punctuation! It annoys people to have to mentally correct your post so they can understand it. We can be a really helpful bunch, but you need to meet us halfway. Thanks!
Re: rear gear ratio - tag missing [Re: Kern Dog] #1192668
03/08/12 02:01 AM
03/08/12 02:01 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
Deal!
Re: rear gear ratio - tag missing [Re: gogo318] #1192669
03/08/12 02:17 AM
03/08/12 02:17 AM
Type like you talk dude We can all read Not all of us are interested in your written english language communication skills Welcome to the board
Re: rear gear ratio - tag missing [Re: Cab_Burge] #1192670
03/08/12 02:21 AM
03/08/12 02:21 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
i fell kinda honored
Re: rear gear ratio - tag missing [Re: gogo318] #1192671
03/08/12 02:39 AM
03/08/12 02:39 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
There is an ongoing tension over grammar here. SOME are very casual and don't mind reading posts with "less than stellar" English. Good for them. They may be poor spellers or maybe they just don't worry about many things. They probably have fewer heart attacks!
Others on this site prefer to read posts that are clear, to the point and have at least High School quality grammar. The simple truth is, the better your skills are, the MORE members there are that will jump in to offer help. I'll be the first to admit though that there are several members on this forum that do NOT have perfect grammar but DO have excellent skills and advice. Welcome to the machine... Don't be a stranger !
