Ladder Bar Question???? #1190468
03/03/12 07:45 PM
03/03/12 07:45 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
How do you determine how far apart to put the ladder bars. I don't see that described anywhere in the instructions.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Ladder Bar Question???? [Re: DemonDust] #1190469
03/03/12 07:50 PM
03/03/12 07:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just inside the rear rails.... keep them as far apart
as possible for more stability
Re: Ladder Bar Question???? [Re: MR_P_BODY] #1190470
03/03/12 11:16 PM
03/03/12 11:16 PM
Menomonee Falls
Menomonee Falls
Thanks mr p. Another question. I found some instructions online and in one of the boxes. It says to have a minimum of .750 to the frame on one and the other says 1.500 per side. Which one would you go with?
SDG Motorsports
Re: Ladder Bar Question???? [Re: DemonDust] #1190471
03/04/12 12:01 AM
03/04/12 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
.750 is plenty... just make sure that its centered
when you determine the .750 so you can get some lateral
movement if needed
