Re: MACHINING PRICES???
[Re: BSB67]
#1188476
02/29/12 08:57 PM
02/29/12 08:57 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
local reputable place from a couple years ago. clean block (thermal degrease & shot pean $65 magnuflux block $50 line hone mains $180 balance rotating assy $225 r & r cam bearings $40 hone with plates & deck $200 clearance block for stroker $175 As steff suggested,shawn will do you right as well.
[Re: RUNCHARGER]
#1188478
02/29/12 10:48 PM
02/29/12 10:48 PM
Posts: 1,973 SoCal
jake4cars
SoCal
IMO: Price of machining is almost a non-factor. Finding a shop that does great machining is all that matters, to heck with the cost.
Sheldon
it is so hard to find a decent shop.
Joey
[Re: Labratt]
#1188479
02/29/12 10:54 PM
02/29/12 10:54 PM
Posts: 68 Detroit, MI
RawnDart
Detroit, MI
Could you guys give me a run down on machining prices? I need to know if a perspective shop is in the "ball park" for their work...which I've heard for years,is TOP NOTCH! Dynamic Speed & Marine..in Harrison Twp. Mi. Thanks in advance for your help!
I use "Automotive Machine Shop" based on Art's (From Mancini Racing) recommendation.
Jack did absolutely perfect work on my stroker motor, and for the whole job it was about $1100. That included line boring the mains, boring .030 over, clearancing for a stroker crank, cleaning the block, sonic checking it, and balancing the rotating assembly for me.
http://automotivemachine.net/
[Re: Labratt]
#1188480
03/01/12 12:02 AM
03/01/12 12:02 AM
Posts: 914 tn
robnbird
tn
I just had a new block bored, deck height matched, line bore maines ck cam jourmal alignment ( one was off and had to hone ) hot washed the block. installed cam brgs, internally Balanced the rotating system. $1100. this machine shop is a performance shop only. Its a spotlees clean shop. when I went in yesterday he was dynoing a 1418 HP pontiac motor, yes he let me watch I spend a lot with this shop. this guy is very good. and just up the road a couple of miles.
[Re: STEFF]
#1188482
03/01/12 07:12 AM
03/01/12 07:12 AM
Posts: 998 Clinton Township, Michigan
Dartin
I think Dynamic Speed & Marine is still on Jefferson, just north of Selfridge. I used them years ago. They were ok.
There's another place very close to you, Randy. St. Clair Engines in Richmond, on Armada Ridge rd. They do good work as well. One of Best Machine's past lead engine builder / machinist works there. His name is Shawn.
X2 for SCE! Shawn is currently building my new motor. Very honest and friendly and do very good work. For a price comparison look on Automotive Machine's website. They are at the corner of Utica Rd. and Garfield in Fraser.
Randy
[Re: STEFF]
#1188485
03/01/12 11:34 AM
03/01/12 11:34 AM
Posts: 2,877 SE Nunya
Bubba
SE Nunya
Another vote for Shawn @ St. Clair Engines...
[Re: Bubba]
#1188486
03/01/12 01:08 PM
03/01/12 01:08 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
I've used LSM in Waterford on the last three, only one of the three was my own, they've always treated me right.
Price wise they're always been on par with the other local race shops.
Rich H.
Esse Quam Videri
