Any downsides to running Napier 2nd rings? #1188138
02/29/12 11:17 AM
02/29/12 11:17 AM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I've already got a set of rings for the 452 rebuild in progress, but I'm considering picking up another set that uses Napier 2nds, rather than a standard style. This is a fresh re-hone for a street/strip piece and my intent is to still run standard-tension oil rings, although the ring set I see that includes Napier 2nds is listed as a low tension. Any downsides (besides having to buy another set of rings) to making this switch? Thanks.
Re: Any downsides to running Napier 2nd rings? [Re: BradH] #1188139
02/29/12 11:48 AM
02/29/12 11:48 AM
SD USA
neonic Offline
neonic  Offline
SD USA
I run and have ran Napier 2nd rings. We use them to help scrape the walls down on alcohol motors. Have not seen them run on a gas motor but would think they would work fine.
Re: Any downsides to running Napier 2nd rings? [Re: BradH] #1188140
02/29/12 12:01 PM
02/29/12 12:01 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
No negative. The special "hooked groove" acts like a one way valve allowing good ring action while relieving any excess pressure between ring 1 and 2. Most of the pro racers use them. They work fine with any oil ring style and any fuel.
On my alcohol motor the oil looks like new when drained. With normal rings I used to get a slight amount of oil dilution.
Re: Any downsides to running Napier 2nd rings? [Re: neonic] #1188141
02/29/12 12:01 PM
02/29/12 12:01 PM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
I've ran them for 4 or 5 years now, on gas I like them.
Have you tryed just buyng the second ring and not a full set?
Re: Any downsides to running Napier 2nd rings? [Re: BradH] #1188142
02/29/12 02:42 PM
02/29/12 02:42 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
All positive in my book.
RIP Monte Smith
Re: Any downsides to running Napier 2nd rings? [Re: SB412DUSTER] #1188143
02/29/12 03:49 PM
02/29/12 03:49 PM
BradH Offline OP
BradH  Offline OP
Not cost effective, from what I see for the price of just the 2nd rings...
Re: Any downsides to running Napier 2nd rings? [Re: BradH] #1188144
02/29/12 04:29 PM
02/29/12 04:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
They work great in my local 93 pump gas engine... One thing I had noticed over my last setup was (I run evac system)is that my dipstic tube doesn't pop out at all like it did some before on the big end
Mopar Performance
Re: Any downsides to running Napier 2nd rings? [Re: moparniac] #1188145
02/29/12 06:13 PM
02/29/12 06:13 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Total seal reccomended them on the boost build we're putting together. Stainless top ring and Napier 2nd rings
**Photobucket sucks**
Re: Any downsides to running Napier 2nd rings? [Re: CompWedgeEngines] #1188146
02/29/12 06:17 PM
02/29/12 06:17 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
mine too...
MB
