TOUGHEST..LONGEST LASTING ENGINE PAINT??? #1184559
02/23/12 01:49 AM
02/23/12 01:49 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
What paint have you guys had the BEST results with...for painting an engine block? I want to use the MOST DURABLE..LONGEST LASTING paint I can find! Oh....also has to be Chrysler Orange..for my 440! Thanks in advance for your opinions! Randy B.
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184560
02/23/12 01:52 AM
02/23/12 01:52 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I use the Engine enamel 1000+ degree stuff from o`reillys..........didn`t even re-paint my engine after the freshen.
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Thumperdart] #1184561
02/23/12 02:34 AM
02/23/12 02:34 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
THANKS,Dom! Does it come in Chrysler Orange?...is it a spray can...or can you brush it on?
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184562
02/23/12 02:57 AM
02/23/12 02:57 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
clean it well and spray it with epoxy primer and then spray it with acrylic enamel and yes they can mix the right color,,you won't be sorry.
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: dartman366] #1184563
02/23/12 07:39 AM
02/23/12 07:39 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Don't clean the bare metal with Lacquer thinner. Use something like PPG DX 440. I also have had better luck with etch primer than epoxy on bare cast iron. Aluminum can use either. I use regular single stage urethane. The chrsler spray isn't bad but its not as good against fuel,brake clean,etc. The urethane isn't fazed by either. This is a 5 year old job we did.
Doug
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184564
02/23/12 09:09 AM
02/23/12 09:09 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
POR 15 ENGINE ENGINE ENAMEL IS INDUSTRUCTABLE
CLEAN THE BLOCK WITH GREASE AND WAX REMOVER AND PAINT AWAY WITH A BRUSH COMES IN ALL CHRYSLER COLORS WONT EVEN COME OFF IN THE HOT TANK
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: BIGSTROKER] #1184565
02/23/12 12:08 PM
02/23/12 12:08 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Endura EX-2C Topcoats or DuPont Imron polyurethane enamels. The machine shop even asked what the paint is on your block it sure doesn't want to come off. I had shot it with Endura and it came out like glass, nice and shiny.
Edit: oops no Chrysler Orange
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: BIGSTROKER] #1184566
02/23/12 12:52 PM
02/23/12 12:52 PM
United States
STLDuster Offline
STLDuster  Offline
United States
I agree! I used that on mine and have had good luck with it. I did mine in blue but, my next one will be orange.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184567
02/23/12 01:16 PM
02/23/12 01:16 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
It comes in an orange but not sure if it`s Chrysler or not.
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Thumperdart] #1184568
02/23/12 02:09 PM
02/23/12 02:09 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Couple of things....
Spray bombs, while easiest to use, are NOT going to be that durable. Hot fuel, brakeclean, or just about any solvent will lift the paint.
As someone earlier posted. Best to spray some Acrylic enamel out of a gun. The important thing I found is that with engines, you need to use a gloss hardener. This will make the paint just about bulletproof. It will be shinier than most, but also much easier to clean. Nice thing about acrylic enamel is if you chip it or have to partialy tear the motor down you can touch it up with a brush with good results.
Oh, and one more thing... If you dont have or dont want to bother with the pro spray gun and paraphernalia, you can use a PreVal sprayer, available at Napa for 5 bucks. Its a sprayer that is self contained and you just fill the jar with paint/thinner/hardener and spray away. Throw it all out when done. I wouldnt paint a car with it, but you can get good results spraying and engine with it.
Good Luck.
MB
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: HPMike] #1184569
02/24/12 01:54 AM
02/24/12 01:54 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thank you ALL for the suggestions! Sounds like more than one method will work well! BTW...LOVE the way that 426 Max Wedge looks!
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184570
02/24/12 09:02 AM
02/24/12 09:02 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
durable and long lasting? nothing from a spray can...
clean, clean, then clean it again ..
then spray on epoxy primer
then use a high solids urethane paint like utech 3.8...
here is the info from the can for a street hemi orange...
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: abodyjoe] #1184571
02/24/12 09:45 AM
02/24/12 09:45 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
lots of good paints out there that you can use, but they do not come in a spray can!
I like the eastwoods ceremic paint with hardener. thin it down a little bit and about 1/3 of a quart is enough to do an entire engine.
the paint cures hard, is nice looking, and cleans well.
here's my engine:
and one I did for another guy:
They have all the chrysler colors too. orange, blue, red...
**Photobucket sucks**
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: HPMike] #1184572
02/24/12 11:46 AM
02/24/12 11:46 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Good Luck.
MB
I'd have to side with Mike B. on this, I too, like to use acrylic enamel with gloss hardner to paint engines, I usually prefer Dupont's Centari line of acrylic enamel,....any color you desire is available...I prefer a medium to heavy wet coat of paint on the engine, I've never had any issues with burn off, or peeling, but a clean surface is a must, i do apply an acid etchant primer base before painting to get some"bite" on the surface though
Mike
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: DAYCLONA] #1184573
02/24/12 01:32 PM
02/24/12 01:32 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Joe,Tom!...your motors look TOO NICE to hide in a car! Mike,I'll keep in mind about using the acid-etchant for "bite" before applying the primer! Thanks guys! BTW..this is the old car it's going back into! Randy B.
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184574
02/24/12 02:26 PM
02/24/12 02:26 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Engine Paint thread from the Best of section
THis link is getting too old now to still have alot of pictures. but I painted my engine the way ABJ stated, and it still looks the same from 2004.
I've since shot about 5 other engines, and they all have the same results.
The etching primer was what I was going to use, but went with epoxy primer - 2 thin coats of that and you will never have a problem - thats the best stuff I have ever used on an engine as I had a fire, several changes and it all just wipes clean year after year with no hassle.
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: Labratt] #1184575
02/24/12 04:33 PM
02/24/12 04:33 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Good thing they went into trucks then!
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: 70Cuda383] #1184576
02/24/12 09:10 PM
02/24/12 09:10 PM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
Toughest? Powder coat, hands down....
Re: TOUGHEST..LONGEST LASTING ENGINE PAINT??? [Re: TooMany62s] #1184577
02/29/12 04:11 AM
02/29/12 04:11 AM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
couldnt agree more........
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
