Re: would street tires cause...
[Re: Mr.Yuck]
#1182726
02/20/12 09:43 PM
02/20/12 09:43 PM
Posts: 4,310 Prospect, PA
BSB67
Prospect, PA
I wonder if the lack of traction wings the motor up quicker opening the outboards faster?
Yes, this can be the reason. This can also happen if you hammer the throttle from a roll starting at an rpm above the converter stall rpm. The signal that the carbs get at the track under WOT from a dead stop with traction is different than on the street from a roll or tires spinning. It becomes more pronounced (i.e. more hesitation on the street) the heavier the car, the taller the gear, and the tighter the converter.
This might not be what is going on with your car, but I will say this with certainty, only adjust the outboard carb opening rates AT THE TRACK.
[Re: BSB67]
#1182727
02/20/12 10:16 PM
02/20/12 10:16 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah I wasn't going to mess with them unless I had issues at the track. so far they've run just fine there. Heay?? about 38-3900lbs 3.91's and 3800 stall.
[Re: Cab_Burge]
#1182729
02/20/12 11:17 PM
02/20/12 11:17 PM
Mr.Yuck
Brookeville, Md
You might want to use a heavier,slower opening, spring on the outboards for street driving, maybe change back them at the track to see which set 60 fts. the best
I have the purples in now. Not to worried about the street.
[Re: Dodgem]
#1182731
02/21/12 03:40 PM
02/21/12 03:40 PM
Mr.Yuck
Brookeville, Md
My guess is you need a higher number PV Dabeast2 just went from a 4.5 to a 7.5 and got rid of his hickup. maybe a 6.5 so you get the power enrichment circit working in time to have the fuel needed there in time!
I had the 4.5's in last season and had no issues. This is really the 1st time I've used anything but the hoosiers on the car. All of the "testing" was done w/ the drag radials. Didn't have any issues at the track, but I do have an assortment of jets, PVs squirters and springs I bring with me.
[Re: 572charger]
#1182733
02/21/12 09:18 PM
02/21/12 09:18 PM
Mr.Yuck
Brookeville, Md
i ran heaver springs on the street and taped off the kill bleeds at the track so they would open up instantly !! back in 1986 ihad a stock 6 pack on a 590 cammd 30 over 440 that would run 11.30sin a 3800 lb charger !!!! i would crush any car on the street with the 6 pack in the 80s
I'm not crushing anything with these tires... 590 is a good cam. I have a 588 solid roller and a stock 6-pack.
