4-Speed Install, Muscle or Jack
#1182219
02/19/12 06:04 PM
02/19/12 06:04 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
What do you guys prefer? Engine is out of the car so I am going to do a mock-up, but when you are under the car, what do you prefer?
Thanks.
383, Hemi 4-Speed, AlterKtion, D60
Re: 4-Speed Install, Muscle or Jack
[Re: Mr.Yuck]
#1182221
02/19/12 06:18 PM
02/19/12 06:18 PM
Crazy68Dart
Canton, Ohio
... and in my case safer. I'm not that big of a guy. This is a cast iron 4-speed.
I was looking at the jack adapters that you remove the pad off a standard jack and replace with a transmission adapter. There is one that seems adjustable which might work. Need to look around some more.
[Re: Mr.Yuck]
#1182222
02/19/12 06:20 PM
02/19/12 06:20 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
I've done auto trans on my back way back.. muuuuuchhhh easier w/ a jack. I'd use a jack.
Definitely use a jack. For the life of me though- why couldn't the trans manufacturers cast the case with a flat pad on the bottom that would sit on a trans or floor jack without tipping over or wanting to fall off all the time
[Re: TooMany62s]
#1182226
02/19/12 09:44 PM
02/19/12 09:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I've always rassled them in and out by hand, but I sure would like one of them jacks.
[Re: Supercuda]
#1182227
02/19/12 09:55 PM
02/19/12 09:55 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
A jack for sure. I have never muscled one in on back, and never will. I have a old floor trans jack that has a large flat pad, but as stated, the way the case is, it just wants to flop around. I would build a simple adapter just for the 833'2 because of this. I have done them on a regular floor jack too, but its a little unnerving when it get some height and I have had them fall off before---thus me reasoning for building a simple and specific adapter. I bet it would cost less than $20 in materials to make.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1182228
02/19/12 10:18 PM
02/19/12 10:18 PM
Crazy68Dart
Canton, Ohio
Gus, you've always got my back, I appreciate it. I'll let you know. I was going to go over to HF and see what they have. I hate supporting that place... but all this stuff is imported, so I guess I'll avoid the mark-up. For, you guys that made the custom adapters? I was thinking about fabbing a small cradle of some sort that followed the contours of the case. Is this how you did yours, or you have brackets, etc. that use some existing holes in the case? Thanks!
[Re: TooMany62s]
#1182231
02/20/12 11:33 AM
02/20/12 11:33 AM
Posts: 1,565 tennessee
pushbutton
tennessee
I bought one of these cheapies from Harbor Freight. I've used it for 833's five or six times. Much easier than muscle especially if your old, like me.
I have one of those too. Know what you mean about the old part also.
[Re: Crazy68Dart]
#1182233
02/20/12 12:30 PM
02/20/12 12:30 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Thanks.
when I was a younger man, I used to bench press them in. It only took a few seconds. Then one day, few years ago, I tried the same tactic. I almost had it and then I couldn't hold it and it landed on my chest. I couldn't get it off. My wife had to rescue me.
So now its a jack and 3 assistants. Takes longer but it sure is safer.
[Re: Moparnut426]
#1182236
02/20/12 01:28 PM
02/20/12 01:28 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
833, I've never worked with, but hear they are heavy!! I'd use a jack. 727, I used a jack. T-56, I slid under the truck, tipped the gearbox up and slid myself under it, then pulled it up onto my chest, then I benchpressed the gearbox up into the bell housing and into position. it was very easy, but that gearbox even though it's big, only weighs about 70-75 lbs. I probably push more weight than that when I'm doing a pushup, and for my annual fitness test I have to knock out about 60 in a minute I did my NV3500 the same way, it's about the same as the T-56 as far as weight, but has that big ole bell housing cast into the case...actually made it easier. gave a nice solid "handle" to grab it and secure the trans with a good grip to angle and wiggle it into position through the clutch. never thought about losing an eye doing it, but ouch, and yea, I could see that happening. I never pushed up though, unless I had a very firm grip on the gearbox first, and felt like I could maneuver it around as needed. as I get older though, and not as strong...I may find myself suing hydraulics more and more
**Photobucket sucks**
[Re: radar]
#1182239
02/20/12 07:24 PM
02/20/12 07:24 PM
Crazy68Dart
Canton, Ohio
I am going to run over to HF tonight and see what they have. I think a second tool for this would be nice leaving the jack handy if needed during the process.
It is the alignment while it mid-air that is the problem, I agree.
The longer stud idea is a good one, not sure what kind of space I am going to have with an A-body tunnel. When I mocked in the car I installed the tranny/bell/block as one. Not sure I am going to do that this time with a fresh paint job in the engine compartment.
[Re: TooMany62s]
#1182241
02/20/12 08:38 PM
02/20/12 08:38 PM
70Cuda383
Marysville, O-H-I-O
Without a doubt, the challenge is getting the splines to line up and mesh home just right so you can stab the gearbox all the way in. I've found that rotating it back and forth and rocking the back of the gearbox in a circular motion makes it the easiest to line it up and slide it home, however, I think the long threaded rod is a great idea! get the weight of the gearbox off your hands/jack, and give you the freedom to wiggle it around while getting the splines to line up
[Re: Crazy68Dart]
#1182245
02/20/12 11:11 PM
02/20/12 11:11 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Seems every time I use a transmission jack, it's just a cumbersome affair, 727 or 883 I usually end up just muscling them in, whether the car is on ramps or a lift,....I'd much rather lift TKO 5spds though, they're only 115 lbs....never did weigh a 727 or 883 For the OP, if you don't muscle "heavy equipment" on a daily basis, you might be better off with a jack, just to be safe.....
[Re: TooMany62s]
#1182247
02/21/12 08:57 AM
02/21/12 08:57 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
That is what I have, work smarter..not harder!
[Re: Crazy68Dart]
#1182248
02/21/12 12:34 PM
02/21/12 12:34 PM
pushbutton
tennessee
I picked up the HF jack. Looks like it will work great. I'm going to make some studs too.
Cut a slot in the end of the studs for a screw driver in addition to the flats,it's pretty close up top.
[Re: Crazy68Dart]
#1182249
02/21/12 01:09 PM
02/21/12 01:09 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
Use a couple of helpers or a transmission jack. I cut the end of my finger practically clean off. I got the trans down out of the car no problem (back when I is in much better shape). But then I had to set it down. It slipped and landed on the end of my finger. A bunch of gauze and a tube of neosporen, and it healed. But did it hurt for a while.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Kern Dog]
#1182251
02/21/12 06:52 PM
02/21/12 06:52 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
I put threaded studs in the bellhousing studs to mount the transmission in all cars I work on. Its not for the increased clamping force, but instead for the ability to line up the trans to slide into place. It really helps!
Bingo! Long screws with the heads cut off and ground to a bull-nose (2 diagonally opposite) make a MT install child's play!
Rick
[Re: B7Satellite]
#1182253
02/22/12 11:44 PM
02/22/12 11:44 PM
Crazy68Dart
Canton, Ohio
Thanks for the tips guys. I didn't expect this thread to hang around this long... I think this will work out great. Already nice to just move it around the garage.
[Re: Crazy68Dart]
#1182254
02/23/12 08:56 AM
02/23/12 08:56 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I also used to just lift them in.Now Im too old for that.Last time I did the 0ne in my 65 I had my 3 sons help.Sure is nice to have 3 grown sons.Especially when they can do mechanical work.I knew I raised them for a reason.LOL. I also made some long studs to help guide the tranny in.Rocky
Chrysler Firepower
[Re: Crazy68Dart]
#1182255
02/23/12 09:16 AM
02/23/12 09:16 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Sure is, I have a 100# Jeep bumper strapped to mine so I can roll it around.
[Re: Crazy68Dart]
#1182257
02/23/12 05:43 PM
02/23/12 05:43 PM
Posts: 828 KS
MoparKansas
KS
And after you get the jack from Harbor freight you can get one of their $9.99 furniture dollies, add a a 2 x 4 and a 4 x 4 and use it to install the k-frame, engine and trans from the bottom. I have done my challenger and my brother's 67 dart this way and it worked really slick...
[Re: MoparKansas]
#1182258
02/23/12 08:45 PM
02/23/12 08:45 PM
Crazy68Dart
Canton, Ohio
The way the factory intended.
I have thought about doing it this way, what is your process? You have most of the suspension removed? I thought I would have issues getting the body back down at the correct height to get the K frame bolts started.
What did you use as a lift point on the body?
[Re: Crazy68Dart]
#1182259
02/23/12 09:14 PM
02/23/12 09:14 PM
Posts: 1,788 Greer, SC
TooMany62s
Greer, SC
The way the factory intended? Why doesn't the factory shop manual say to pull it out the bottom?
[Re: Crazy68Dart]
#1182260
02/24/12 01:11 PM
02/24/12 01:11 PM
Posts: 828 KS
MoparKansas
KS
The 4 x 4 and the 2 x 4 got the K frame and engine to nearly the exact proper height. I also wanted an edge to jack on with the 2 x 4 in case I needed adjustment (dolly is too low to get a jack under, but neither car I did needed it. Of course the trans jack makes it easy to adjust height in the back. On my challenger I ran a 3 x 3 wood piece under the frame rails and hooked a tow strap to it and in my brothers dart there were holes in the frame rail that we put the straps hooks to.
I didnt get a good pic down low on that shot, but it has all of the suspension on with the exception of torsion bars which are sitting in the car. I did my challenger all by myself just starting the engine hoist down very very slowly and moving things as needed. Main thing to watch was upper a-arms, steering box on drivers side and valve cover clearance on the blower motor on passengers side of the dart. Also if you run some type of bar across the engine bay under the frame rails to hook the hoist to make sure the k frame will clear it in the front. I had no room on my Challenger, but on the dart with the holes in the rails it was a piece of cake. 71 T/A had some brackets made to bolt into the bumper bracket holes that he used when he did his car if I remember right.
My bother had some larger sheet metal valve covers on the dart which made that pretty tight putting the 383 in. When dropping from the top it is pretty easy to get the motor swinging and dinging something, and it seemed much less likely with the hoist letting the body down slowly. I don't have the dolly at my house right now or I'd take a pic. I actually welded up a big t thing like others have shown, but it was too big to store and I gave it away when I moved and lost my 40 x 84 shop. It will work with either manual (Challenger) or auto (Dart) and the added benefit is that you don't try and line up the trans input shaft or tighten torque converter bolts or trans to engine bolts under the car asthe trans and engine are already bolted together.
The combo of the trans jack and the furniture dolly made it easier to split and store (also lighter) and I can use the furniture dolly for other stuff if I want to. Sorry for so few pics, but I get to working and forget to take them. It was really easy by myself, but I would suggest a helper if you have one.
[Re: Crazy68Dart]
#1182261
02/25/12 05:32 PM
02/25/12 05:32 PM
Rick_Ehrenberg
Marlboro, NY, USA
Last few times I was lucky enough to have a lift. But in the past, I have done it many times with an engine crane and chain to the 2 center bumper bolts!
Check the video - no scratches, no cursing, no hassles. Pie! (2 long studs, ground to a bull nose, in 2 diag.-opp K-member bolt holes in rails).
Body Drop
Steering, headers, tranny, engine harness, etc. all preassembled. I'll never drop an engine in from the top again. Never. Later projects, I had all the suspension on, too - UCA's dangling, as at the ass'y plant.
Rick
[Re: Crazy68Dart]
#1182262
02/25/12 11:44 PM
02/25/12 11:44 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Here is a pic from Gorski's thread about installing a four speed in a weekend. I was guiding the input through the T.O. bearing while a few other members provided the muscle Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Rick_Ehrenberg]
#1182263
02/25/12 11:54 PM
02/25/12 11:54 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Body Drop
Rick
I've read this guys articles for years, but this is the first time that I have heard him SPEAK! He sounds different than I thought he would. I forgot that he is from New York!
