#1181705 - 02/18/12 03:59 PM 1969 B body manual disc brakes help
Ok, here is my dillema. I want to run a factory mopar style disc brake set up on my car with 10 inch rear drums and a 1969 B body manual master cylinder. Is there any simple type swap that I can do to make that happen? Im ok with running a 1970 and newer spindle, rotor and caliper set up. The issue is that I have to run a 1969 B body manual master cylinder for sure. Any help would be great
#1181706 - 02/18/12 05:03 PM Re: 1969 B body manual disc brakes help [Re: ]
can.al Offline
Loc: Ontario.Canada
..anything '73 and later A E or F body.
..transfer everything between the ball joints.
..remove the residual pressure valve from the master cylinder to the front lines.
..big rear tires,smaller rear wheel cylinders or prop valve in rear line.
#1181707 - 02/18/12 06:27 PM Re: 1969 B body manual disc brakes help [Re: can.al]
Joshs68 Offline
Loc: Overland Park, KS.
my 68 has manual disks/drums. used 73 satellite knuckles and outer parts. I dont remember what master cylinder was used. used a proportioning valve from a dart with factory manual disk/drum setup
#1181708 - 02/18/12 06:28 PM Re: 1969 B body manual disc brakes help [Re: ]
gtx6970 Offline
Loc: Land of Booze and Horses
I'll have to ck but I don't think the 69 B-body disc brake master cylinder has provisions to retain a manual brake push rod.
#1181709 - 02/18/12 08:46 PM Re: 1969 B body manual disc brakes help [Re: ]
moparbuff Offline
Loc: St. Louis, MO
I use 1970 B-Body manual disc brake master cylinder with manual brake push rod.. Still have the original 1969 GTX disc brakes on my car. It has been this way for 20 years.
#1181710 - 02/18/12 09:32 PM Re: 1969 B body manual disc brakes help [Re: moparbuff]
70440+6bbl Offline
Loc: NY
Was a '66-70 B-body even available with manual discs? I don't think so, however, it seems most rebuilt master cylinders with after market rebuild kits I have run across tend to have the retaining ring groove machined in the piston.
#1181711 - 02/19/12 05:02 AM Re: 1969 B body manual disc brakes help [Re: 70440+6bbl]
therocks Offline
Its Lost
Loc: Niles , Ohio
I run 69/70 C body disc/drum masters in all my conversions.My 65 has one in it now.Been in at least 15 years.It manual brakes.Rocky
Chrysler Firepower
#1181712 - 02/19/12 08:57 AM Re: 1969 B body manual disc brakes help [Re: therocks]
I dont have a problem running a body knuckles, calipers and rotors. The issue is maintaining the correct looking master cylinder.
#1181713 - 02/19/12 09:51 AM Re: 1969 B body manual disc brakes help [Re: ]
6T9_CHARGER_RT Offline
Loc: S.I. N.Y.
When I first got my SSBC front disc kit to replace my manual drum brakes, it came with what I believe was an A body disc master.
Ran the car with this for a while till I upgraded to the correct Bendix power booster & master...
#1181714 - 02/19/12 09:56 AM Re: 1969 B body manual disc brakes help [Re: 70440+6bbl]
gtx6970 Offline
Not as far as I know,,,at least not between 1967 and 1971
The only available manual disc brake car was A-bodies
#1181715 - 02/20/12 10:07 AM Re: 1969 B body manual disc brakes help [Re: ]
torkrules Offline
I'm neurotic
Loc: closer to Canadian beer!
What I did was use the rotors,calipers, and lower control arms from a 70 B body. It uses a different sway bar and mount so the calipers don't interfere with outer mounts of the sway bar.
You need to use a master cylinder without the residual valve. I used the newer style Mopar master cylinder (the flat one, not the angled one)
Missing the old days when men were men and parts had quality.
25,346 Registered Members
190,221 Topics
1973 Satellite Sedan
by moparmike1
06/22/18 05:46 AM
1969 Plymouth Road Runner
by tomsjack
06/22/18 04:47 AM
CARBON FIBER HOOD
by A/MP
06/22/18 12:22 AM
TUNING W2 HEADS
by A/MP
06/22/18 12:15 AM
