1969 B body manual disc brakes help
#1181705
02/18/12 06:59 PM
02/18/12 06:59 PM
Ok, here is my dillema. I want to run a factory mopar style disc brake set up on my car with 10 inch rear drums and a 1969 B body manual master cylinder. Is there any simple type swap that I can do to make that happen? Im ok with running a 1970 and newer spindle, rotor and caliper set up. The issue is that I have to run a 1969 B body manual master cylinder for sure. Any help would be great
Re: 1969 B body manual disc brakes help
[Re: 70440+6bbl]
#1181711
02/19/12 08:02 AM
02/19/12 08:02 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I run 69/70 C body disc/drum masters in all my conversions.My 65 has one in it now.Been in at least 15 years.It manual brakes.Rocky
Chrysler Firepower
[Re: therocks]
#1181712
02/19/12 11:57 AM
02/19/12 11:57 AM
I dont have a problem running a body knuckles, calipers and rotors. The issue is maintaining the correct looking master cylinder.
[Re: ]
#1181713
02/19/12 12:51 PM
02/19/12 12:51 PM
Posts: 3,967 S.I. N.Y.
1MYTGTX
S.I. N.Y.
When I first got my SSBC front disc kit to replace my manual drum brakes, it came with what I believe was an A body disc master. Ran the car with this for a while till I upgraded to the correct Bendix power booster & master...
1MYTGTX
[Re: 70440+6bbl]
#1181714
02/19/12 12:56 PM
02/19/12 12:56 PM
Posts: 21,398 It's a dry heat
gtx6970
It's a dry heat
Was a '66-70 B-body even available with manual discs?
Not as far as I know,,,at least not between 1967 and 1971
The only available manual disc brake car was A-bodies
[Re: ]
#1181715
02/20/12 01:07 PM
02/20/12 01:07 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
What I did was use the rotors,calipers, and lower control arms from a 70 B body. It uses a different sway bar and mount so the calipers don't interfere with outer mounts of the sway bar.
You need to use a master cylinder without the residual valve. I used the newer style Mopar master cylinder (the flat one, not the angled one)
