65-69 b body sway bar bushings #1178867
02/15/12 04:24 PM
02/15/12 04:24 PM
Does anybody reproduce the sway bar bushings for 65-69 B bodies that attach the bart to the k frame? All I see is urethane and Im curious if the O.E type rubber is available anywhere?
Re: 65-69 b body sway bar bushings [Re: ] #1178868
02/15/12 05:16 PM
02/15/12 05:16 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
'65-early '66 are different from the later ones. completely different sway bar setup.
Re: 65-69 b body sway bar bushings [Re: NicksGarage] #1178869
02/15/12 07:10 PM
02/15/12 07:10 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
The triangle shaped jobbies? I got mine on ebay.
Scott
1969 Super Bee, 383/4 speed
