wiper gear repair- what epoxy to use? #1177529
02/13/12 01:36 AM
02/13/12 01:36 AM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
I have been looking all over for a gear to replace the cracked one in my 65 New Yorker, but there are none available. The gear has absolutely no wear, since car was originally owned by a little old lady who obviously did not drive in the rain. It does, however, have a couple of cracks radiating out from the center post. They do not go out very far, looks like plastic shrinkage. Anyways, I figure the best way to repair it is to dremel out the crack with a small ball tool and fill it with epoxy. My question is what type of epoxy to use. This is a white plastic gear, very hard. Any ideas on this? Thanks- Pat
Re: wiper gear repair- what epoxy to use? [Re: Carsavior] #1177530
02/13/12 01:45 AM
02/13/12 01:45 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
JB Weld - the miracle two-part epoxy.
Re: wiper gear repair- what epoxy to use? [Re: MoparMarq] #1177531
02/13/12 09:25 AM
02/13/12 09:25 AM
CrazyD Offline
CrazyD  Offline
search 'mopar wiper gear' in eBay - there are several single and variable speed gears for early & mid 60s cars - maybe one matches yours.
The gear is probably nylon, not sure anything will stick to that for long.
Re: wiper gear repair- what epoxy to use? [Re: CrazyD] #1177532
02/13/12 09:34 AM
02/13/12 09:34 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
Email me a picture of your gear.
I may have one for you.
gdaddio@videotron.ca
Jules
