Re: Show me your belt driven fuel pump
[Re: W9 Dart]
#1175781
02/10/12 12:43 PM
02/10/12 12:43 PM
Posts: 3,104 Wheels up, MO
nhramark
Wheels up, MO
No pics on this computer but: Mine is mounted to the motorplate, with a -10 line coming in and a -8 line going out to a fuel log. (single dominator) There is a return line from the back of the log to regulator & the underhood mounted 3 gallon fuel cell. I have mine set for 3 lbs at idle and 12 lbs at WOT. 2 tips: 1) do not use too small of a fuel line from the cell to the pump. 2) Very important - make sure your fuel cell has plenty of venting. If not it will act like a 2 liter bottle turned upside down..... don't ask me how I know. I love my belt driven system. Nothing to remember to turn on or off, zero draw on the battery, and no stuck floats from too much psi at idle.
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image]
9.100 @ 150 mph
5.780 @ 120 mph
[Re: Biginchmopar]
#1175784
02/10/12 06:31 PM
02/10/12 06:31 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I don't think I have a picture I will check,but Ron's makes a nice kit for the Mopars it mounts to the pass.(2,4,6,8) side of block off the timing cover the kit includes everything needed.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: bigtimeauto]
#1175789
02/11/12 05:53 PM
02/11/12 05:53 PM
Posts: 16,917 NC
440Jim
NC
I have the Ron's Fuel belt driven fuel pump and their mounting kit on my BB Mopar. And I am running their Flying Toilet injection system. They have diagrams of their pump mounting kits on their website (under "diagrams"). http://www.ronsfuel.com/pdfs/4095.pdfThe only thing I don't like is the crank drive "mandrel" which has a 1/2" bolt. That isn't very useful for turning the engine over by hand against compression.
[Re: bigtimeauto]
#1175790
02/11/12 07:19 PM
02/11/12 07:19 PM
Posts: 243 United States
W9 Dart
United States
here is how i do it with a rear mounted tank:
I don't see anything
[Re: Biginchmopar]
#1175795
02/11/12 08:10 PM
02/11/12 08:10 PM
W9 Dart
United States
Here are a couple:
Tell me more about that alt bracket?
This is the web page:
http://www.dotymi.com/Home.htm
There are a couple of things he makes that are really good.
I'm really diggin that bracke with the crank trigger and alt on it.... I wonder if it will work on my SB?
