Re: Neutral safety switch--------------Where to find one???
[Re: bboogieart]
#1175199
02/10/12 11:57 AM
02/10/12 11:57 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Later switch. The later comb has an extra contact point to turn on the back up lights. So yeah now you can see the rooster comb would need to be replaced as well, as the extra point for reverse is between the park and neutral. Basically this comb is longer and has an extra tab. Just swap both and eliminate the back-up light wires from the system. I suppose the valvebody might need to be switched as well(?) When the weather gets warmer, I will pull both apart and see just what needs to be done. Still, never say can't , say how . Of course the $45.oo dollar price isn't looking as bad. Might get a couple of those myself. Don't see 'em getting any cheaper.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1175201
02/10/12 02:04 PM
02/10/12 02:04 PM
Posts: 32,918 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
The rooster comb is simply the name for the trigger for the switch.
Look at the picture of the three levers (rooster combs) and the switchs below each one. You can see that there are two legs that work the first switch ,a notch and a leg for the second switch and a ramp for the third three prong style. You can see that they will not work if switched around. The switchs screw into the trans at different depths also. They won't work unless they are matched sets lever and switch.
You contardict yourself with this last statement. You said it can't be done, and then explain how they can. Hmmm.
Here is the picture that is in the tech archive article.
Although they look different. it appears as though any could be used. The last comb seems to have a high spot where the middle one has a valley, that high spot would be for the back-up lights. After the neutral both combs ramp down to release the switch. For the sake of not having to do it twice I might just replce the rooster comb as well. Here is the picture that is in the tech archive article.
The first one was for pusg button trans the second one is the 66 thru 68 switch and the last one is the 69 & later switch
I Did not conterdict myself.I was addressing the fact you can't swap styles of switchs without swapping levers. Which was for the benefit of the original poster from whom you highjacked this thread.
[Re: stumpy]
#1175202
04/01/14 06:23 AM
04/01/14 06:23 AM
Posts: 3 Louisiana
sparkzz
Louisiana
Hello,
Can anyone tell me where I can get the "comb" for the 3 prong NSS for the A727 transmission, and what is it really called? I have a '94 B250 van with backup light issues, and that may be the problem.
I have searched all over and was fortunate to find this thread.
Thanks.
[Re: sparkzz]
#1175203
04/01/14 03:39 PM
04/01/14 03:39 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory name for the roostercomb or cockscomb is "Lever, Manual Valve".
What is the issue with the BU lights? If they stay on in every gear, the plastic shoe is broken/missing...can't think of any other issue that would be the roostercomb's fault.
[Re: bboogieart]
#1175204
04/01/14 03:50 PM
04/01/14 03:50 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
IIRC member Joesix pack has them.He should have them in the parts section.I know there was at least 1 listed last month.Rocky
Chrysler Firepower
[Re: John_Kunkel]
#1175207
04/02/14 03:40 AM
04/02/14 03:40 AM
Posts: 3 Louisiana
sparkzz
Louisiana
Thanks for all the info, guys. The problem is that I have to jiggle the gear shift while in reverse to find the "sweet" spot that illuminates the BUL's. I've already replaced the NSS twice, so this is about the only thing left. I found out this morning that the part is called a "detent lever" and you can buy a "neutral safety switch detent insulator" kit to replace the insulator. This is about the only thing left, other than a bent or out-of-alignment lever, itself. One other thing that has crossed my mind is maybe the NSS is too long,or installed too tight in the socket. I have temporarily wired a 12v micro-buzzer in the reverse light circuit so I can tell when the BUL's are on. Not really a big thing to me, but the people at the state inspection office would think differently. LOL
Thanks again, Ken
[Re: sparkzz]
#1175208
04/02/14 03:49 PM
04/02/14 03:49 PM
John_Kunkel
Rio Linda, CA
Having to jiggle the linkage might be because one of the plastic bushings in the linkage is worn or has fallen out, lay under the car while somebody manipulates the linkage and look for lost motion in the linkage.
Also, it's not uncommon for the shaft in the "detent lever" to come loose and result in lost motion; check for this by disconnecting the linkage from the shift lever and operating the lever by hand...there should be no lost motion between the clicks.
