'71 318-four speeds in an e-body possible?
#1169172
01/31/12 03:05 AM
01/31/12 03:05 AM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Ola's e-body 'vert registry lists 6 318 4-speed Barracudas, including one with a shaker.
Is it possible to have such an engine/trans combo in 1971? I just flat out don't believe the 318 shaker car.
BH27G1B 189799 A20 TU 4 sp U x722x GY3 H6XW V3W B51,C16,C55,G36,P37,R11
BH27G1B 388298 5xx 4 sp ? x722x EV2 H6X9 V3X BH27G1B 390008 513 SA 4 sp U x722x GB5 H6XW V3W A01,A36,B51,C16,C55,G37,H51,J45,J54,M21,P31,P37,R21,26
BH27G1B 426254 611 FR 4 sp U x722x GY3 H6X9 V3X C55,Rxx
BH27G1B 4 sp ? x722x GY3 H6X9 V3X V6X A01,A22,G36,J25,J45,J81,L34,M25,M31,M88,N41,N42,N96,Rxx
Then there's also 3 Challenger 318s w/4-speeds:
JH27G1B 154809 924 TH 4 sp ? x2165x FC7 H6XW V3W V5W C16,C55,G36,H51,M31,P37,Rxx,26
JH27G1B 156875 9xx 25 or 26 4 sp U x1793x FE5 H6X9 V3X A62,G33,N85,P37
JH27G1B 238789 C09 TU 4 sp U x1793x TX9 H6X9 V3X V5X A46,C55,G15,G31,G33,L31,M31,M42,M44,P37,R11
Re: '71 318-four speeds in an e-body possible?
[Re: 2fast4yourBrain]
#1169173
01/31/12 03:45 AM
01/31/12 03:45 AM
Posts: 17,515 Las Vegas, NV
6bblgt
Las Vegas, NV
Yes, 1971 & 318 & 4-spd is possible in a Barracuda convertible - the '71 production numbers are a bit messed up, but in '70 ~58 were built (US spec.). The lack of a VIN# on the one with the N96 would lead me to believe that those are visual clues to ID it if further info became available. Here's a '70 Barracuda convertible factory pink, 318, 4-spd, A/C, & AM/FM. pic "stolen" from pantherpink.com
[Re: 6bblgt]
#1169174
01/31/12 01:51 PM
01/31/12 01:51 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
I was specifically referring to 1971s. According to: http://home.earthlink.net/~mopared/productionchange.htm"8/20/70: Code D21, 4-speed transmission, is not available with 198, 225, 318 or 383-2v engines. " I guess there could have been a few 1971 four-speed 318s squeek through before that date.
[Re: DAYCLONA]
#1169176
01/31/12 03:12 PM
01/31/12 03:12 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
a shaker on a 318 would have to be a one off base plate to fit a 2 barrel. and if they would have had a 318 4 bbl (not optional), more than likely it was dealer installed.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: GuruRanger]
#1169178
01/31/12 05:11 PM
01/31/12 05:11 PM
Posts: 915 near New Haven, CT
fireeng
near New Haven, CT
How does it ( N96 ) get on the fender tag if it was dealer installed???
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
[Re: 6bblgt]
#1169180
01/31/12 06:18 PM
01/31/12 06:18 PM
6bblgt
Las Vegas, NV
[Re: 6bblgt]
#1169185
01/31/12 07:41 PM
01/31/12 07:41 PM
fireeng
near New Haven, CT
I believe my 71 318 was built sept 22, 1970. My vin is jh23g1b150402, does this mean I have the 402nd challenger built at hamtramck?
#1169186
01/31/12 08:02 PM
01/31/12 08:02 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
All of the E44/D21's I have are after that date. I think that source may be inaccurate.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: fireeng]
#1169187
01/31/12 08:04 PM
01/31/12 08:04 PM
69CoronetRT
Harlan, Iowa
No...it means your car had the 50,402nd VIN assigned to all cars built at the plant. With only a couple of exceptions, VINs were not assigned sequentially by makes and/or models.
Seeking:
[Re: 69CoronetRT]
#1169188
02/01/12 07:54 AM
02/01/12 07:54 AM
fireeng
near New Haven, CT
Thanks for the explanation. Sorry for the hijack.
[Re: fireeng]
#1169189
02/01/12 12:51 PM
02/01/12 12:51 PM
Posts: 477 Clarkston,MI
Todd_DesMarais
super street
super street
Clarkston,MI
"Can anyone tell me if the 318 rallye challengers or cudas in 73 and 74 came with duel exhaust and/or four barrels? " This is a great question as my car is a true 318 'Cuda (BS23G4B14xxxx) but the trunk pan has the single tip hanger and no evidence of a second pipe. Kinda hard to imagine a real 'Cuda with a non 'Cuda valence panel. BTW, mine was a yellow/blk top 318/904, A/C, rear swaybar, console, non-ralley car. Now it's a hulk of metal & parts waiting patiently in the corner. Todd
aduC' 47
IIeredevleB 66
383 etilletaS 66
DTC 0053 MAR 50
"ssenlli latnem a dna ,ybboh a neewteb enil enif a si ereht"
