yellow wire under dash 70 b body? #116882
09/07/08 07:34 PM
09/07/08 07:34 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
what does this yellow wire go to under the dash at the steering column? it is a round male/female connector. it was unplugged when i got the car and wonder what it goes to.
Re: yellow wire under dash 70 b body? [Re: satgtx] #116883
09/07/08 07:35 PM
09/07/08 07:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Courtesy light for the key...
Re: yellow wire under dash 70 b body? [Re: 1_WILD_RT] #116884
09/07/08 07:37 PM
09/07/08 07:37 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
wow thanks, i will go check this out right now.
Re: yellow wire under dash 70 b body? [Re: satgtx] #116885
09/07/08 07:44 PM
09/07/08 07:44 PM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
yes the light is on, does it ever go off? or is this why it was unplugged, car was sitting for 22 years before i got it. It is not very bright but it is there
Re: yellow wire under dash 70 b body? [Re: satgtx] #116886
09/07/08 10:29 PM
09/07/08 10:29 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It will be on with the door open or for typically 30-45 seconds after the door is closed...It it stays on the delay timer has failed in the on position...The delay timer is plugged into the wiring near the yellow wire, fact is the yellow wire is one of the three wires going to the timer....It is a cylinder about 1.25" long by .75 around....They are still avalible from the dealer or half the mopars at the JY will have one...
Re: yellow wire under dash 70 b body? [Re: 1_WILD_RT] #116887
09/08/08 07:16 AM
09/08/08 07:16 AM
Maryland, USA,
satgtx Offline OP
satgtx  Offline OP
Maryland, USA,
yes the delay timer is there, i wondered what that was as well. i will check to see if the light goes out after a minute or so.
thanks
