Page 1 of 3 1 2 3
Rear drum to disc conversion SSBC kit question #1159693
01/17/12 09:34 PM
01/17/12 09:34 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I am interested in installing the SSBC rear disc kit in place of my factory drum brakes in the road runner. I was wondering if anyone has done this before and just how simple is it? I am asking as i have to do it in the driveway of my house and soon it's going to be raining so is it an easy one day project or not?
Also do i need any special tools of just the basic stuff we all have.
Thanks for any advice.
Stu
http://www.ssbrakes.com/commerce/detail/index.cfm?nPID=8568
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159694
01/17/12 09:42 PM
01/17/12 09:42 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
for Stu.
I used another kit and had to have the axle ends machined, brake hose tabs welded and other minor stuff.
I'll defer to others that have actually used THIS kit, but the consensus here seems to be the Dr. Diff kit.
If your luck is the same on this as it was for the 'bolt-in' transmission, make sure you have triple A to tow it to a shop!
Re: Rear drum to disc conversion SSBC kit question [Re: RodStRace] #1159695
01/17/12 09:44 PM
01/17/12 09:44 PM
for Stu.
Hummn?? Sounds like more than just a few hours in the driveway swap.
Do you have a link for the Dr. Diff kit i can check out??
Thank you
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159696
01/17/12 09:46 PM
01/17/12 09:46 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
He's a member here, but I did a search and here's his current ebay listing
http://www.ebay.com/itm/Chrysler-Mopar-8...rts_Accessories
Re: Rear drum to disc conversion SSBC kit question [Re: RodStRace] #1159697
01/17/12 09:55 PM
01/17/12 09:55 PM
Thank you for taking the time to post that. Hopefully i will get some more input on the SSBC kit as i wanted to use the same company as when i did the front conversion.
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159698
01/17/12 10:02 PM
01/17/12 10:02 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Anything for the garage door king and proprietor of the MPM clubhouse!
BTW, I got a BB shorty 727 trans. I may end up with a BB in the van...
Re: Rear drum to disc conversion SSBC kit question [Re: RodStRace] #1159699
01/17/12 10:16 PM
01/17/12 10:16 PM
Right on!!
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159700
01/18/12 07:52 AM
01/18/12 07:52 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
That's the '85 Caddy Eldorado caliper kit. Master Power, etc., all use it because it simplifies the park brake deal. The calipers are kinda weird, but, you you follow the instructions, they DO work, although I don't know if I'd trust the PB in San Francisco!
I've had this setup on one car for almost 10 years with no problems.
Anything Dr. Diff sells is likely to be excellent, just don't swap to "Green" wheel bearings.
Also check scarebird.com
Rick
Re: Rear drum to disc conversion SSBC kit question [Re: Rick_Ehrenberg] #1159701
01/18/12 11:28 AM
01/18/12 11:28 AM
I called SSBC just now and said the kit they sell uses parts from a 1988 Turbo Thunderbird.
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159702
01/18/12 11:51 AM
01/18/12 11:51 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's correct Stu,...SSBC rear disc kits are all that I use on my cars or customers cars,... Ford Thundercoupe rotors and calipers have always been the supplied componets in the kit, the rotors are redrilled to slip on the mopar axle studs, you'll need to remove the axles (naturally) the kit will have a spacer to replace the clearance lost by removing the drum backing plate, so no need to remove the thrust button if your doing an 8 3/4 axle, you will need to switch over to the GREEN Bearings, regardless of what the naysayers say, there's nothing wrong with using them, I've used them, as have my customers for decades with no issues or failures, street, track, or road course cars that have been equipped with them,....however: your emergency brake cables can be used with no mods, the only thing to remember is to install the calipers on the correct side of the car with the bleeders as high as possible, and to use the shims provided to center the caliper over the rotor for equal pad wear/placement, flex lines are provided to adapt to your existing hard brake lines, now is the time to replace any old lines on the axle, they do offer lines alredy done for the rear disc brake set-up if you desire new lines, you will have to reshape/direct your existing ends, so if they're in sad shape?...replace
So if you have the tools/equipment to change out to Green Bearings, assorted hand tools, brake tubing tools (possibly needed) it is a 2-4 hr change out
The Dr Diff kits have provisions for the tapered bearing adjuster should you decide to go that route and keep the factory adjuster/bearings...perhaps Cass will chime in with a run down of his install guidlines for you?, or PM him
Mike
Re: Rear drum to disc conversion SSBC kit question [Re: DAYCLONA] #1159703
01/18/12 12:00 PM
01/18/12 12:00 PM
Wow lots of great info there Mike!! Thank you!! I think i will pass the job on to a local shop as it sounds like more than i want to get into in my driveway.
BTW i have always heard of "green bearings" but just what are they?
Thanks again
Stu
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159704
01/18/12 12:30 PM
01/18/12 12:30 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159705
01/18/12 02:31 PM
01/18/12 02:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Thanks again
Stu
Stu,... Green Bearings are a ball bearing design, the originator of GREEN Bearings was Chrysler, it was a replacement bearing assy offered thru MOPAR to replace the tapered roller bearing assy found in production chrysler vehicles, Green Bearing allow you to loose the adjuster assy/preload required with the tapered bearings...Green Bearings, Chrysler's and other designs have been the topic of yea or nay amongsts motorheads for a few decades, some swear by them, some swear at them,.....myself I've used them the better part of 2 decades on the street/track/course with no failures, guess it boils down to installation for some?...almost every vehicle produced (re: Millions of vehicles, where's those massive failures ?) in the last few decades uses a "Green" style bearing, more and more track/course even circle cars are running Greens......if you do decide to use Greens use the snap ring style, Dr Diff sells those also
mike
Re: Rear drum to disc conversion SSBC kit question [Re: DAYCLONA] #1159706
01/18/12 02:58 PM
01/18/12 02:58 PM
Ohio
Todd Offline
Todd  Offline
Ohio
This is a SSBC kit on the 64 with a Dana. Went together pretty easy.
Re: Rear drum to disc conversion SSBC kit question [Re: Todd] #1159707
01/18/12 04:39 PM
01/18/12 04:39 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Hey Stu...My Brother Jon aka: stubbs300 (now banished from MOPARTS) did a complete disc swap on his 66/300...the Red and White one he had at last years Half Moon Bay/Dream Machines event. A few years ago he and I both did the SSBC conversions. I went with disc fronts and he all the way around. We did have the AF Base hobby shop available which made it easier but the swap on his ride went as advertised. Albeit a little massaging was required. In addition to the brake swap on the rear, we replaced the bearings with the Greens. This was done because it was easier to set up the rear system with them. I know a lot out there don't like them...EBooger included, however in my opinion they are fine for what we use our rides for. Too much purist for me as the taper vs Green. I have them on my 66 Sat project and I am not worried. Anyway...Back on topic...The overall install and performance of the rears coupled with the fronts is outstanding. His 4000 lb C Body will stop on a dime and then give you nine cents change. That is how good they are...IMHO. As a side note...if you have some time and can get up to Travis AFB area, I can get you into the Hobby Shop as a guest and we can turn it into a joint effort. I know the manager real well and my Brother and I do a lot of work on our rides there. Lifts, air, specialty tools, you name it. Top notch too....cr8crshr/Bill...
Re: Rear drum to disc conversion SSBC kit question [Re: CR8CRSHR] #1159708
01/18/12 05:38 PM
01/18/12 05:38 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
So what takes the side loading when you go around a corner with a GREEN bearing installed in a 8 3/4 diff? Isn't that what the tapered bearings are for? I know on a GREEN bearing type diff that was designed for it (ie 8 1/4 and 9 1/4) it's taken up by the snap rings and transfered to the carrier bearings, at least thats the way I understand it.
Re: Rear drum to disc conversion SSBC kit question [Re: CR8CRSHR] #1159709
01/18/12 09:21 PM
01/18/12 09:21 PM
Thanks guys for all the great info! I am in between choosing the SSBC or the DR. Diff kit.
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159710
01/18/12 11:06 PM
01/18/12 11:06 PM
Marlboro, NY, USA
Marlboro, NY, USA
"Green" (brand) ball bearing conversions were originated by...The Green Ball Bearing Co. (now part of Bearing Technologies, Avon, Ohio).
MP has sold them, with the catalog proviso: "for drag racing use only", for quite a while. They definitely make life easier if you're making frequent "pig" swaps; however, being ball (vs. huge OEM Timken tapered rollers) they, of course, have a small fraction of the load carrying capacity. I have never personally seen a set last more than 10K, the stockers can go 250K.
I was originally worried that they would fail catastrophically, but they do seem to give plenty of warning - "snow tire" type noise. Still, they are a much weaker design -- this is intuitively obvious to even the most casual observer.
I'd personally not even do even one high-speed road-course lap, or one Auto-X lap (with sticky tires) with 'em.
Rick
Re: Rear drum to disc conversion SSBC kit question [Re: MidPenMopar] #1159711
01/19/12 01:14 AM
01/19/12 01:14 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My kit uses '94-'04 Mustang Cobra rear calipers. The Cobra calipers are actually a descendant of the Turbo Coupe units.
The following link shows a few pictures of my 10.7" econo and premium rear disc brake kits.
https://board.moparts.org/ubbthreads/show...amp;Search=true
Re: Rear drum to disc conversion SSBC kit question [Re: DoctorDiff] #1159712
01/19/12 01:32 AM
01/19/12 01:32 AM
Thank you taking the time to post that. What is the differnce between the econo and preminum kits?? I was looking for the one that has the parking brake set up included.
Page 1 of 3 1 2 3
