Re: New Project 1972 Satellite Part 2
[Re: moopa]
#1157955
04/16/12 01:23 AM
04/16/12 01:23 AM
Posts: 375 An Island in the Pacific N.W.
moopa
Using the following blasting equipment: homemade pressure blaster, confined space blower,uses 12" accordion style vent tube, and finally, a fresh air breathing unit...it's such a dirty messy job...but at least I'm doing it at home and not having to pay someone else to do it. Mark [image] [/image] [image] [/image]
2015 TorRed Challenger Hellcat,A8
2013 Plum Crazy Challenger SRT8,6 Spd
2013 Black Challenger R/T Classic,auto
(2)72 Satellites, one on hold,one under resto on the rotisserie.
[Re: moopa]
#1157956
09/19/12 02:52 AM
09/19/12 02:52 AM
moopa
A ha! Stalled but not forgotten. Here's the new rotisserie, with the Satellite mounted and ready for even more good things to come!
[Re: moopa]
#1157957
09/19/12 02:56 AM
09/19/12 02:56 AM
moopa
Now to photograph all the underside stuff before I get started.
[Re: 71DemonRON]
#1157959
09/20/12 10:51 PM
09/20/12 10:51 PM
moopa
Thanks Ron! Any luck selling your beast?
[Re: moopa]
#1157960
09/20/12 10:59 PM
09/20/12 10:59 PM
moopa
I want to make sure I know where all the little brackets for fuel and brake lines go, before I remove all of them! [image]http:// [/image] [image]http:// [/image]
[Re: moopa]
#1157961
09/20/12 11:10 PM
09/20/12 11:10 PM
moopa
I was searching for photos of brackets used to mount a 71-72 Plymouth B Body to a rotisserie, but didn't see any I liked. The rotisserie manufacturer suggest using the single bolt hole mounts....and it made me queezy, so I came up with these front mounts that use the front bumper bracket bolt holes.( the factory single hole mount brackets slide through the brackets I made out of 3" angle iron and 2 1/2" square tubing. Due to to offset of the bumper bolt holes, I needed to weld a piece of 1/4" flat bar to the angle iron.) They are very stable, and with the set bolts, I can slide the brackets to get the front rotisserie assembly as close as I want it. [image]http:// [/image] [image]http:// [/image] Then for the rear I fabbed up some stout brackets that mount to the rear spring mount. Even though its only mounted with one bolt, I added some 2"x 1/4" square tubing between the frame and bracket to prevent pivoting. [image]http:// [/image] [image]http:// [/image]
