Re: Coming to a strip near you, 25.5 (70) Challenger
[Re: 6PKRTSE]
#2436489
01/17/18 06:50 PM
01/17/18 06:50 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Looks and sounds good. Just out of curiosity, why wasn't the vacuum pump used in the video?
[Re: ProSport]
#2436507
01/17/18 07:20 PM
01/17/18 07:20 PM
Posts: 4,562 Motor City
6PKRTSE
Motor City
That video happened to be the first pull. The pump belt was put on after a couple of pulls.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: second 70]
#2437469
01/19/18 02:20 PM
01/19/18 02:20 PM
6PKRTSE
Motor City
Thanks for the compliments. Just wanted to build something different. Tired of all of the Chevy's & Fox Body Mustangs everywhere at all of the tracks. Gets old, gets boring.
[Re: Cab_Burge]
#2437553
01/19/18 04:44 PM
01/19/18 04:44 PM
6PKRTSE
Motor City
LOL, you had to go 1 more page. It is on the bottom of Page 7.
[Re: 6PKRTSE]
#2440949
01/26/18 12:57 PM
01/26/18 12:57 PM
6PKRTSE
Motor City
I picked up a Shaker hood. Next project is to make a custom drop base & a larger/taller Shaker scoop to fit the tunnel ram & dual Dominator carbs.
[Re: 6PKRTSE]
#2440950
01/26/18 12:58 PM
01/26/18 12:58 PM
6PKRTSE
Motor City
Close fit.
[Re: 6PKRTSE]
#2441017
01/26/18 03:10 PM
01/26/18 03:10 PM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
I'm looking forward to seeing what you do w/ that shaker scoop! I'd like to have one for my car, even though I love my cowl hood. Mike Ford's old KOS challenger (plum crazy w/ a single carb B1 motor IIRC) had a raised shaker scoop that I always thought was cool. Harry Schilling has one on his burgundy/maroon hemicuda too that looks good.
[Re: an8sec70cuda]
#2441038
01/26/18 03:53 PM
01/26/18 03:53 PM
6PKRTSE
Motor City
I just can't bring myself to do the cowl hood as good as they look on E Bodies. I have thought about doing an extra tall T/A style hood like 340Rick had or a 5" tall Six Pack style hood.
Yeah, I always dug Mike Ford's old Purple Challenger's set up. I do have to stretch the rear of the hood opening to clear the rear carb so the base & scoop will also be stretched & raised to match the opening.
[Re: 6PKRTSE]
#2441048
01/26/18 04:16 PM
01/26/18 04:16 PM
an8sec70cuda
I'm assuming you'll just attach the scoop to the hood? Is the hood a fiberglass lift-off?
[Re: an8sec70cuda]
#2441061
01/26/18 04:39 PM
01/26/18 04:39 PM
6PKRTSE
Motor City
Nope, I am still making it a true shaker. The Scoop & base will mount to the engine. The hood is a Fiberglass bolt on. I am going to still use the factory Hood Pins but I know I will also need more to keep the front from ripping off of the car, so I am going to make a mount to attach some Butterfly Dzus fasteners from up underneath that will mount from the hood latch area that will be accessible reaching in towards the grille.
[Re: 6PKRTSE]
#2441146
01/26/18 07:25 PM
01/26/18 07:25 PM
an8sec70cuda
That sounds like it'll be very nice! I'm sure you've seen them already, but the way Schilling's is done...he raised the area around the scoop on the hood up and then left the shaker itself looking more stock height. Mike Ford's was all done by making the scoop itself taller. I think Schilling's hood looks better.
[Re: an8sec70cuda]
#2441224
01/26/18 10:23 PM
01/26/18 10:23 PM
6PKRTSE
Motor City
Schiling's looks pretty good like that. I am going to try to leave the hood at it's stock height and since I am stretching the opening towards the rear a few inches the taller scoop should look more proportional since it will be longer also.
[Re: V10nacuda]
#2441341
01/27/18 01:59 AM
01/27/18 01:59 AM
6PKRTSE
Motor City
Will do. I am gathering the rest of the parts now. I found the scoop from one source. The base plate and adapter ring from another source and the seal, fasteners,and of course the shaker decal and other bits from a third source.
[Re: 6PKRTSE]
#2454647
02/20/18 04:57 PM
02/20/18 04:57 PM
6PKRTSE
Motor City
I received everything for my shaker scoop, base plate, outer adapter ring & lid today. Let the cutting & hacking begin.
[Re: Uncle Barry]
#2454787
02/20/18 10:01 PM
02/20/18 10:01 PM
Posts: 1,505 TN
SCATPACK 1
TN
I have nothing to add to this thread. I'm just here to keep checking up on this awesome build . Great job. Great looking car Yeah, what he said.
Old Geezer Racing
