Re: Coming to a strip near you, 25.5 (70) Challenger
[Re: 590 Challenger]
#1992780
01/17/16 05:41 PM
01/17/16 05:41 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
25.3 book only shows the 25.3 spec. Yes it calls out every mandatory bar, dia. and wall thickness. 25.3 is not that much more work and it's a little heavier and safer. I think 25.5 you have a choice of mild or moly where 25.3 is moly only and has to be tig welded So the 25.3 just shows the add on bars to what? 25.5 or where does it show the whole frame concept? I would do moly so tig is no problem. I bend and weld my stuff so I can conform to my size. So should I get the 3,4and 5 to lay a good foundation and build up from there?
[Re: FastmOp]
#1992910
01/17/16 08:21 PM
01/17/16 08:21 PM
cudaman1969
fredericksburg,va
The SFI chassi book for the cert you want is about 40 dollars. It list every bar and size. There well worth the money. Found that site awhile back, I'll order both tomorrow and see how they look, thanks
[Re: cudaman1969]
#1999801
01/27/16 03:27 PM
01/27/16 03:27 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
No further picture updates yet. Just buying more parts to get a little further, I have new MSD crank trigger, distributor, wire set to be made, Meziere electric water pump & figuring out the front drive assembly mounting everything to the front plate with a vacuum pump & alternator now.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#2106964
07/09/16 08:07 PM
07/09/16 08:07 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Beautiful car,I'm a little partial to B5 though.
Mopar to the bone!!!
[Re: 6PKRTSE]
#2106983
07/09/16 09:18 PM
07/09/16 09:18 PM
Posts: 8,160 Plymouth, MI
Blusmbl
Plymouth, MI
Ahh, so that was your Hemi on the Roush Engines facebook page a couple days ago!
[Re: Blusmbl]
#2107053
07/09/16 11:44 PM
07/09/16 11:44 PM
6PKRTSE
Motor City
Yes, everyone was kind enough to give me my own build area to stay after and machine, assemble, fabricate whatever I needed and dyno once I was done.
[Re: 6PKRTSE]
#2120903
07/29/16 09:05 PM
07/29/16 09:05 PM
72Swinger
Nebraska
I feel sorry for that transmission already.
[Re: 72Swinger]
#2120920
07/29/16 09:23 PM
07/29/16 09:23 PM
cudaman1969
fredericksburg,va
I feel sorry for that transmission already. You do know up until the early-mid 70s, Hemi funny cars ran torqueflites
[Re: 6PKRTSE]
#2121175
07/30/16 10:58 AM
07/30/16 10:58 AM
6PKRTSE
Motor City
The trans will hold up fine for now. With today's power management capabilities I will be taking power out of it to get it to leave anyway and bringing both kits in. Thanks for posting the latest pictures Jeff.
[Re: 6PKRTSE]
#2122523
08/01/16 11:54 AM
08/01/16 11:54 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
[Re: 6PKRTSE]
#2122593
08/01/16 01:44 PM
08/01/16 01:44 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The trans will hold up fine for now. With today's power management capabilities I will be taking power out of it to get it to leave anyway and bringing both kits in. Thanks for posting the latest pictures Jeff. Ratio will be the issue. 2.45 low on radials, lots of nitrous, big block = nearly impossible to manage early. You should look into a 2nd gear leave valve body
[Re: Monte_Smith]
#2122793
08/01/16 06:22 PM
08/01/16 06:22 PM
6PKRTSE
Motor City
It's not makimg that much power. That will be an upgrade eventually. Right now I just have to run with what I have.
