Tic toc Tach wiring harness #1155264
01/12/12 03:00 PM
01/12/12 03:00 PM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
I am placing a order at Year 1 for wiring harnesses,and not sure which one to get for the tach.I have a 70 roadrunner,which had the rally gauges with no tach or clock,and i am adding a original Tic toc.There is 2 differant ones listed ,L38499 and TAC141.I talked to M&H and they were a little unsure and suggested HU6869.Has anyone done this Thanks
Re: Tic toc Tach wiring harness [Re: cudablues] #1155265
01/17/12 02:12 AM
01/17/12 02:12 AM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
If I were you I would not order it from Year One. I would order it from MegaParts in WI. They are probably cheaper on the price of the part and they will for sure be cheaper on the shipping. (608)452-2045 ask for Roy or Jamie.
Re: Tic toc Tach wiring harness [Re: dsd70bee] #1155266
01/17/12 11:36 AM
01/17/12 11:36 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Gary, you could try and give Frank Baldalson a call and see if he can help. Sometimes he can offer some advice even if he dosent have the part.
http://www.rogergibsonautorestoration.com/
Re: Tic toc Tach wiring harness [Re: LimeliteAero] #1155267
01/17/12 09:46 PM
01/17/12 09:46 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Bill Evans should make the harness you need as well..
www.evanswiring.com
1MYTGTX
Re: Tic toc Tach wiring harness [Re: 1MYTGTX] #1155268
01/17/12 10:25 PM
01/17/12 10:25 PM
California
mickm Offline
mickm  Offline
California
i also would not order it from year one. i got mine, including harness, from charger specialties.com. nothing but the highest recommendations for the product and customer service.
sorry to throw another vendor in the mix!
