A500 vs. Gear Vendors
#1151134
01/05/12 11:58 PM
01/05/12 11:58 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Dropping a '95 360 Magnum in a '72 Charger with a 904. It appears to buy a built A500 to replace the 904 is going to be well over $2000. The question is, for the money and the headache, if you were going to spend $2500 on an A500 why not just buy a Gear Vendors and make it simple?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: A500 vs. Gear Vendors
[Re: dfsmopars]
#1151136
01/06/12 12:29 AM
01/06/12 12:29 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Rebuilt, fully warrantied A500s around here are less than 1000. Both will require shortened drive shafts and tunnel massaging. The only advantage for GV is that usually the cross member needs less work, I am not sure about on your car but on Ebody that is true. Add to that, the better OD ratio for the 500 and it kind of tips me to the 500 over the GV.
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1151137
01/06/12 10:11 AM
01/06/12 10:11 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
A500 all the way....
1) A500/42RH has the low first/2nd vs. an older 904 (2.74/1.54 vs. 2.45/1.45)
2) A500/42RH has a lockup torque converter to help drop cruise RPM
3) A500/42RH has a .69 OD ratio vs. .78
4) newer 42RH's have an improved converter hub design that is much less likely to crack (and that I'd recommend looking for)
IIRC on later B's, with some trimming of the ribs on the OD tail section, there is no floor pan/tbar crossmember cutting required, but you'll have to make your own lower bolt on mount/crossmember
[Re: patrick]
#1151144
01/06/12 03:47 PM
01/06/12 03:47 PM
Posts: 502 St Louis, Missouri
Runnin74
St Louis, Missouri
Too big at the rear.
a500 and 518 tail sections are the same. they will fit under a stock late B and E body floorpan with some trimming of the external case ribs.
Patrick, When you say late b-body, is that 73-74 and later?
[Re: Runnin74]
#1151145
01/06/12 05:41 PM
01/06/12 05:41 PM
patrick
Grand Haven, MI
IIRC '71 up....search the forums, I know way back there was a post with pictures...
[Re: patrick]
#1151146
01/06/12 05:55 PM
01/06/12 05:55 PM
Posts: 2,254 IL
furious70
IL
I have an a500 in my Fury and I'm very happy with it. Required 0 modification to the car, just had to have a new cross member and had to adapt a B&M cable for use with the OEM console shifter. We've had GV in a truck and it just plain didn't make enough difference to be worth it at .78 IMO. FWIW I think I paid around $3200 for mine, and that was drive in drive out with a 383 sitting in front of it. I have a 727 bell welded on and the trans sits exactly where it should in the car so that all kick down and shifter linkage work perfectly and there are no shims to deal with.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: dfsmopars]
#1151149
01/06/12 11:19 PM
01/06/12 11:19 PM
dfsmopars
Kentucky
OK, it looks like the A500 is the ticket. I have two builders with very similar prices. So I have to decide which one makes the most sense for me. I can install it and make my own cross member. Getting closer to that cross country road trip all the time.
[Re: dfsmopars]
#1151150
01/07/12 12:16 AM
01/07/12 12:16 AM
Posts: 669 Michigan, USA
ramman5600
Michigan, USA
This is some info that I recently got from a reputable company that sells both options when I was inquiring about the GV vs a 518. "Having reviewed your tech submission and your request for information on our overdrive transmissions for your '70 Superbee with the 6.1 hemi, I offer the following information for your consideration. As I had previously indicated, installation of the A500 or A518 will require extensive modification of your crossmember and floor pan modifications. In addition, the A500 or A518 will drastically increase the elapsed time on the strip by at least 1/2 second in the 1/4 mile, which in a street application will certainly be noticed in performance potential. The option that I highly recommend for your application is our StreetPro 727A with the "Shortie Overdrive" option. This unit is only 7 1/4" longer than your 727 and is a direct bolt-in (other than driveshaft shortening). There are no floor modifications or crossmember fabrications required to install it the '70 B body. When installed, it will have fully automatic overdrive shifting functions like a new car. We have seen mileage increases as high as 50% with this unit. Dropping your cruising rpm drastically reduces engine wear and maintenance. This unit does not substantially increase power drag (slower e..t.) like the A518 Chrysler overdrive. The "Shortie" version of our Street Pro series transmission has 4 direcct clutches and the 4 pinion planetary to take the extra load of the overdrive, which will also accomodate any future plans to increase your torque and horsepower up to the 500 h.p. level. For greater details see our website." Just wanted to share and have no interest in this company.
[Re: DaytonaTurbo]
#1151151
01/07/12 12:17 AM
01/07/12 12:17 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
I would pull a A500 from a junkyard truck for 100 bucks and pocket the rest. Or spend some of the money and rebuild/upgrade the A500. The 500 has a better overdrive ratio than the gear vendors and can be done substantially cheaper if you build the trans yourself.
I never saw one for $100 at the bone yard...Mine was $800 and in very good condition out of a 91 van. The problem with them is the OD, the way the factory lets it slide into lock is not very good for a hot rod. Some things need to be changed to make it work, and the valve body is the main area of changes. I recomend SMR trans for the parts and the changes needed. I run one with 4.56 gears, and shift into it at full throttle at times. Locks in just like any other gear when I flip the switch.
The GV unit will take 0hp away from your normal 3 speed operation where as the A500 is always robbing some hp because it drives thru the OD all the time. They say it can rob as much as 1sec in ET...
Also, if you use the lock-up, meaning a good lock up converter, your limited to about 400-450hp as the shaft into the converter is hollow. With the none lock-up converter, the shaft is a normal solid one, and it uses a normal 904 converter.
[Re: ramman5600]
#1151152
01/07/12 12:52 AM
01/07/12 12:52 AM
Posts: 4,127 Ramona, CA
NicksGarage
Ramona, CA
What is this overdrive system? Is it a GearVendor product?
When I was building my '79 Dodge B+ motorhome I considered going to a 518 trans because my exsting trans was shot and I can get the 518 for less than a hundred bucks at the half price sales at the junkyard. I was looking at this type of conversion - http://www.transmissioncenter.net/SwapInformation.htm
Before I committed to it I asked around if this transmission would be a good choice for a motorhome (weighs 6500 pounds) and was told that the overdrive part would be too weak for this application. I ended up just building a standard 727. I would have liked the extra mileage. Now I have a new '74 camper which is around 7000 pounds and interested in overdrive again but this rig already has a good 727 in it and wonder if this shortie overdrive would work.
[Re: Dragula]
#1151155
01/07/12 01:03 AM
01/07/12 01:03 AM
ramman5600
Michigan, USA
Curious about thoughts on how much impact reducing engine rpm from 3100rpm @ 70mph (std 727 trans) vs 2550rpm @ 70 mph (with Gear Vendors) would have on the a 6.1 L hemi Mileage? Wear and tear? Noise? Other thoughts? -C
[Re: NicksGarage]
#1151156
01/07/12 01:18 AM
01/07/12 01:18 AM
DaytonaTurbo
Manitoba, Canada
I have never seen one scrap of evidence to back up this claim. Not saying it's impossible, but I have never seen anything to substantiate this at all. Until I see a real, all things equal comparison between the two, I'm going to have to put this one right up there with the other myths like the thin wall 70's 440 blocks and low nickel late 70's mopar blocks.
So they didn't think the 518 would work in a 6500-7000lb motor home but it works just fine in dodge pickups that weigh 5000lbs on their own + tow that much in trailers, cars, campers, etc. A good rebuild kit and the transgo tfod-hd2 shift kit is the ticket. With the right combination of parts you can also install extra clutches in the overdrive tail unit.
[Re: BDW]
#1151159
01/07/12 03:59 AM
01/07/12 03:59 AM
NicksGarage
Ramona, CA
Here is the shorty..
http://smrtrans.tripod.com/smrtransmissionsintro/id32.html
THE "Shortie" overdrive option can be added to any of the above transmission models for the additional cost of $2,825.00. I just lost interest!
Yeah it would take a lot of miles for me to pay for that in gas savings. I almost bought a Class C motorhome for $1500 that had a gearvendor in it. This was before I got my own motorhome so I would have had to figure out what to do with the rest of it. It wasn't a bad motorhome just a lot bigger than I wanted.
[Re: wireweld]
#1151160
01/07/12 04:04 AM
01/07/12 04:04 AM
DaytonaTurbo
Manitoba, Canada
smr transmissions did a comparison on a small block dodge dakota between a 727 and a 518. Lost a full second e.t. with the 518. Same truck, engine, rear and track.
I'm sure a company that specializes in 727 and 904 AND sells the gear vendors units is absolutely unbiased.
Where's the data? Specs on the transmission builds? Was this a bone stock w/ stock converter 518 left in drive versus a 727, converted to roller internals with an aftermarket converter, valve body and shifted manually?
Take a stock unrebuilt 727, stock unrebuilt non-lockup 518(so you can put the same converter on both) and actually rebuild both transmissions COMPARABLY. Then run then down the track 10 times each and get back to me. Until someone does that, everything is heresay and myth.
[Re: dfsmopars]
#1151161
01/07/12 06:56 PM
01/07/12 06:56 PM
denfireguy
Colorado
If the GV overdrive had the same overdrive ratio, I would possibly consider it. But at 15000 miles a year with 20 miles to the gallon and gas at 6 dollars a gallon, the break even point for the GV at $3k would be over three years. Since most of us are not going to get 20 mpg and we will drive less than 15000 and hopefully gas does not make six dollars, payback will be even further into the future. The A500 at half the price and better ratio makes better sense to me.
[Re: denfireguy]
#1151162
01/07/12 08:25 PM
01/07/12 08:25 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
The 518 can in no way rob more HP than a GV. The 518 only adds roteing weight in 1st 2nd and 3rd, no other "drag" is added, the pump is not doing any work holding clutches or bands or line preasure or any thing. The GV adds a similar amount of rotateing weight in all gears combined with an almost useless extra gear. The OD section can easily have clutches added, if you use the 48RE OD section it can handle 800 lbs tq easily! As for the 1 second difference in ET from a 727 to a 518 I say BULL CRAP! Like I mentioned earlier, there is a few pounds added to the rotateing weight, thats IT! In first second and third there is some extra weight and in no way can those few extra pounds knock off 1 second in ET. If the trannys get equal prep it can't be more than a couple tenths. If 5-10 pounds in rotateing weight could really knock off 1 second then every car could switch from a steel drive shaft to carbon fibre and gain a second
[Re: HotRodDave]
#1151163
01/07/12 08:50 PM
01/07/12 08:50 PM
Dragula
Its funny the people commenting on the facts when they don't own or drive either of them...Where are your "facts"? The fact that most seem to agree upon is that neither are are cheap, and I can say if you skimp on an A500 rebuild, it will come back out when it does start slip.
[Re: DaytonaTurbo]
#1151164
01/07/12 10:08 PM
01/07/12 10:08 PM
patrick
Grand Haven, MI
yeah, I'm calling shenanigans on this claim, too...especially when a mid-late 90's dak with a 318 and a few bolt on's is a high 13 second ride....I can't see swapping from a 518 to a 727 or 904 getting it into the 12's.
granted my 5th ave is a mild build, at the time a XE262,header, and RPM air gap equipped 360 long block, but I saw no appreciable difference going to a 904 with a MP166K converter and B&M trans pack shift kit to a A500 with the same converter and trans go TFOD shift kit.
[Re: HotRodDave]
#1151166
01/08/12 12:37 AM
01/08/12 12:37 AM
ramman5600
Michigan, USA
Show us the math on the "worthless extra gear". I'll even give you the parameters. 3.73 rear gear, 28" tall rear tire, 4000lb car.
Also has anyone factored the cost of modifying the trans tunnel or the loss of perceived value with a hacked up cross member?
[Re: ramman5600]
#1151167
01/08/12 01:08 AM
01/08/12 01:08 AM
patrick
Grand Haven, MI
the worthless extra gear comment meaning this:
3rd (direct) at 75mph with 28" tires and 3.73 assuming no converter slip: 3350 RPM, mist likely 3500 w/converter slip
gear vendors OD drops it to 2650 RPM no converter slip, most likely 2800-2850 with slip
518 OD drops it to ~2320 RPM, with no converter slip. you won't have converter slip if using a lockup converter...
IMHO a .78 OD is not enough OD to warrant the cost...
[Re: patrick]
#1151168
01/08/12 01:14 AM
01/08/12 01:14 AM
ramman5600
Michigan, USA
IMHO a .78 OD is not enough OD to warrant the cost... [/quote}
Cost aside - 700 rpm drop is not worthless. The 518 is better from that standpoint, but what option do you have if you don't want to hack up your car? Keisler GM adaptation? Better first ratio and as good or better O/D ratio.
[Re: ramman5600]
#1151169
01/08/12 01:15 AM
01/08/12 01:15 AM
DaytonaTurbo
Manitoba, Canada
Well if you can't manage the tunnel/crossmember mods yourself, then chances are you can't fab your own trans mount for the 518, and chances are you can't build your own 518 either. So if you have to farm all that out, you are probably at the same $ level as a gear vendors.
FWIW, the OP asked about a 72 charger. A 72 charger will not need the tunnel or crossmember modded. A 70 or earlier b-body would need those mods. If you have a car that would need the crossmember modded, and you're not comfortable with that, then yes chances are you would be happier with a gear vendors or a chevy 700r4 based auto like the keisler 4-sp auto. Also, from what I've gear, the gear vendors units still do require you to your tunnel for clearance. You don't have to and but it's not a straight bolt in either from what I've read.
[Re: ramman5600]
#1151170
01/08/12 01:16 AM
01/08/12 01:16 AM
DaytonaTurbo
Manitoba, Canada
IMO it is worthless when you consider a comparable or lesser cost option like a 500/518 or chevy 700r4 will deliver a much superior overdrive ratio.
[Re: dfsmopars]
#1151173
01/08/12 11:53 AM
01/08/12 11:53 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
I would add Gear Vendors for one simple reason. I don't think MYSELF would change an original part of my car, just making upgrades. Gear Vendor is an upgrade of the original part, is an ADD ON section on my original tranny.
Otherwise, I think there is not 727 replacements with OD for BBs... or yes ?
But that's me
anyway, I can't afford it LOL
[Re: NachoRT74]
#1151175
01/08/12 03:34 PM
01/08/12 03:34 PM
DaytonaTurbo
Manitoba, Canada
But that's me
All the overdrive options discussed in this thread are able to be used with a big block.
[Re: wireweld]
#1151176
01/08/12 03:38 PM
01/08/12 03:38 PM
DaytonaTurbo
Manitoba, Canada
What about the 200r4? Same ratio as the 904 w/low gear set and a nice .67 od. Can handle a good amount of power when built right. And no tunnel mods, just need to redo the cross member.
Yes, the GM 200-4R or the 700-R4 can be used. The 700 has the lower 3.00 first gear and the 200 has a 2.75 I think. Both are still lower than any stock 727. Either one can be built to handle a good amount of power and both are small enough to not require any crossmember or floor pan mods. You will still need to fab your own trans mount however. I think the only other real issue with those transmissions is you will need an aftermarket shifter. Their shift pattern is is PRND321 where the gear vendors and 500/518 have an electronically activated overdrive gear and will mate up to your stock shifter.
[Re: DaytonaTurbo]
#1151177
01/08/12 04:30 PM
01/08/12 04:30 PM
HotRodDave
Kalispell Mt.
So the GV needs NO fabrication to fit? You can't tell me the GV will fit with no mods to the floor pan, it is much fatter than a driveshaft. Patrick is right on about the my " ALMOST useless extra gear" comment so I won't explain it again. The GM tranny does not just "bolt right in". How you gonna bolt in your starter? How you gonna hook up the kick-down cable to your carb? How you gonna bolt it to your mount? How you gonna bolt it to your drive shaft? I doubt it will turn out the exact same length, gonna have to shorten or lengthen the drive shaft, what about u-joints? Can you get one that adapts to a mopar drive shaft with a GM spline? I am not saying the GM trans won't work, it is gonna take a adapter plate, new converter and a whole lot more little things to figure out for a tranny that is no better than an A-500. BTW the shifter is of little concern, it just won't sho the extra position on the indicator but it will still work with a little creativity. If you go with a generic trans don't waste time with the 200 go straight to the 700R4, the 2004R needs lots of mods to handle any serious power and FYI the 200metric and 200C are 3 speeds.
[Re: HotRodDave]
#1151178
01/08/12 06:29 PM
01/08/12 06:29 PM
Posts: 921 Chicago illinois
ChinooK440
Chicago illinois
I installed a G.V. unit in a 67 B body about 5 years ago and all that was needed was a slight amount of about the size of a Quarter.to the trans tunnel in one spot ..... The entire installation took about 6 hours including multiple beer breaks. If anyone considers that fabrication they probably spend to much time fabricating Doobies ! As far as a reduction of 700 rpm being useless??? There,s pro,s and Con,s to everything & It,s nice to have choices . some engine/gear combos might not need such a steep o.d. ratio . If i had a small block like the o.p. i would have went with a 500/518 instead.
[Re: DaytonaTurbo]
#1151179
01/08/12 07:18 PM
01/08/12 07:18 PM
Posts: 99 South Dakota
wireweld
South Dakota
Wilcap makes an adapter for this app.. I will use a floor shifter any so that will be taken care of. And yes you will need to make a trans mount, but how hard can that be, the 518 you need to do this also.
[Re: HotRodDave]
#1151181
01/08/12 08:21 PM
01/08/12 08:21 PM
DaytonaTurbo
Manitoba, Canada
Fab work is definitely needed for the chevy transmission, along with an adapter such as the wilcap plate mentioned. However if a person has a car in which a 500/518 won't fit without modding the crossmember, and if said person is dead set against that, doing a bit of extra work to get the chevy transmission to work would more likely to be worth it to them than it would be to you or me. I would sooner just mod the crossmember if it really needed it, because none of my cars are worth much anyway, I'm not scared of modding and it's not visible after.
You say the 200-4R is the weaker one, others online say the 700-R4 is the weaker one. I don't know who is right, I've heard claims both ways. I don't really care because I'm not in the market for either of those transmissions anyway. I know both of them will need more upgrades dumped into them to holdup behind a big block, where a 518 with a race rebuild kit and that transgo shift kit will do the job. To run the GM trans, at a minimum you will need a new driveshaft, trans adapter, fab trans mount and an aftermarket kickdown cable. Not sure what speedo cable will mate that trans up to your stock speedometer but I'm sure there's one. The point is it can be done with a reasonable amount of work.
[Re: DaytonaTurbo]
#1151183
01/08/12 08:33 PM
01/08/12 08:33 PM
wireweld
South Dakota
All these items can be done, even the speedo cable you can get. So, it is up to the owner as to which way to go. I would use the reverse manual vb on either tranny, if it were me. I like to shift gears without the clutch. Also, all these items you would need for the 518, except the adapter.
[Re: cogen80]
#1151185
01/09/12 05:33 AM
01/09/12 05:33 AM
DaytonaTurbo
Manitoba, Canada
from what i understand the 200 you only have to mod the bolt in part of the cross member. the 518 you have to cut the hell out of the upper ( welded to the floor) part of the cross member. the 200 would be a lot easier swap then the 518 in my opinion.
Again, it depends on the vehicle. The OP was asking about a 72 charger. A 518 will fit in an e-body or 71+ b-body without having to chop the torsion bar crossmember.
One other thing to consider, last time I checked, the JW ultra bell to bolt a 518 to a BB was around $250 cheaper than that wilcap adapter, not to mention probably having to buy a special aftermarket flex plate to run the chevy torq converter. I know they also make an ultra bell to mate a BB to a chevy th350/400 trans but not sure if that would also work on a 200-4r or 700r4
[Re: dfsmopars]
#1151187
01/10/12 12:49 AM
01/10/12 12:49 AM
dfsmopars
Kentucky
Thanks for all the input. I am still studying. I can't ever remember taking more time to decide on something on a build than this topic.
[Re: dfsmopars]
#1151188
01/11/12 05:35 PM
01/11/12 05:35 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'm putting a 518 behind the TT440 in my 72 Imperial. The Ultra Bell is already in my garage.
[Re: dfsmopars]
#1151189
01/12/12 12:39 AM
01/12/12 12:39 AM
dfsmopars
Kentucky
HotRoadDave, a PM sent your way again.
