Wiring Harness Question #1146056
12/28/11 10:02 PM
12/28/11 10:02 PM
Ohio in the USA
O
Omni Source 1 Offline OP
O
Ohio in the USA
Good Evening All and Happy New Year.
Looking for a wiring harness (Mopar Part Number 3513510). This is a 'jumper' harness that was used on tilt column B Bodies (1971) to connect the tilt column to the main dash harness.
I've contacted M&H (supplier for Year One) and apparently they either have no clue or do not produce this harness.
Evans wiring does not produce anything for the dash/steering column.
New/Used (servicable) not fussy. Just need one to complete the installation.
All replies welcomed.
Thanks to all.
Omni
Re: Wiring Harness Question [Re: Omni Source 1] #1146057
12/30/11 05:57 PM
12/30/11 05:57 PM
Arizona
az426john Offline
az426john  Offline
Arizona
This may be a bumb question, but did you ask they if they would be willing to make one using your existing one as a template?
There are times when vendors will not say no to a specific question even if they do not normally reproduce a specific item.
Just a thought.
Re: Wiring Harness Question [Re: Omni Source 1] #1146058
12/30/11 07:13 PM
12/30/11 07:13 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if hitting a junk yard isn't in the cards maybe you could take your wiring diagram over to NAPA, collect the right colored wires and terminals and make one yourself?
Re: Wiring Harness Question [Re: az426john] #1146059
12/30/11 11:03 PM
12/30/11 11:03 PM
Ohio in the USA
O
O
Ohio in the USA
Good Evening
M&H will produce one, provided I send them a core. They do not have the original prints. Problem is, I do not have a core. I'm converting a non-tilt wheel car to a tilt wheel.
I have no problem fabricating one (lots of scrap harness from scraping cars). What I do not have is the 'plug' for the bottom of the tilt column.
Thanks for the replies
Happy New Year
Omni
