Pic needed on factory quarter/roof joint, 70 challenger #1145150
12/27/11 04:41 PM
12/27/11 04:41 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
A close-up of how the factory did it would be much appreciated. I have a full quarter and a donor roof which was cut off a couple of inches above the factory joint. I plan on extending the roof down to intersect the quarter lap joint prep, but not sure how the edge of the extension will connect to the understructure. Pic is where I'm at now. thanks
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: varunner] #1145151
12/27/11 04:42 PM
12/27/11 04:42 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
other side
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: varunner] #1145152
12/27/11 04:48 PM
12/27/11 04:48 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: Alaskan_TA] #1145153
12/27/11 07:25 PM
12/27/11 07:25 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Thanks. It looks like the roof flange that spot welds to the rain gutter just entends down, and maybe that edge is trimed back a little. If anyone has a shot looking towards the rear of the car would be great.
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: varunner] #1145154
12/27/11 08:05 PM
12/27/11 08:05 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
If you go to "Members Projects and Survivor Pics" there is a thread in there called Jake's Challenger project and he has some good pics in there, you'll just have to look for them, but its some good info for a e-body and some good work.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: bobbyb] #1145155
12/27/11 08:47 PM
12/27/11 08:47 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I've seen Jakes post, pretty impressive undertaking, didn't see a detail shot like I want, thanks anyway. I should be good to go now.
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: varunner] #1145156
12/27/11 08:57 PM
12/27/11 08:57 PM
midwest
68427vette Offline
68427vette  Offline
midwest
if you need more or diff angle let me know
I'll get more for you , all different angles,, !!
Re: Pic needed on factory quarter/roof joint, 70 challenger [Re: 68427vette] #1145157
12/27/11 10:02 PM
12/27/11 10:02 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
Thanks for the pics. How about one from this angle....
