Re: Fresh Magnum 318 is a DOG!
[Re: RapidRobert]
#1145017
12/29/11 11:40 PM
12/29/11 11:40 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Well, I made it out there tonight. I degreed it with the used chain and with the new double roller. The used chain showed to be roughly .5* retarded. The new chain was 1* retarded, which I corrected with an offset keyway. I verified my numbers three times. I just don't get it. Unless its just because the engine only has about 1 hour of run time and 4 miles on it. Perhaps the rings need to seat. I didn't lean on it too hard, but part throttle was definitely off. I guess ill throw it back together and see how it does. This was mainly a mpg build, however I didn't want to use the stock roller cam, as I figured that would make it even worse in the get-up-and-go department
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#1145018
12/30/11 01:04 AM
12/30/11 01:04 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'd advance it 4* to get better low end
