Which Balancer #1142732
12/23/11 09:24 PM
12/23/11 09:24 PM
NY
Beep Beep Offline OP
NY
I am building a stroker out of a low deck 400 block. I need a good aftermarket harmonic balancer that can adapt my 4 groove crank pulley and have no alignment issues. My current pulley is from a 73 440 but I was able to ream the bolt holes in order to fit my 69 original 383 balancer. Any recommendations? Mancini sells the pro sport balancers but according to someone I spoke to it will not work.
Re: Which Balancer [Re: Beep Beep] #1142733
12/23/11 10:07 PM
12/23/11 10:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use the Pro Sport one from Mancini on my 493 and my buddies 440. Both work good and the stock pully's line right up. Ron
http://chucker54.stores.yahoo.net/prosport1.html
Re: Which Balancer [Re: Beep Beep] #1142734
12/23/11 10:12 PM
12/23/11 10:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you want the best..... ATI
Re: Which Balancer [Re: MR_P_BODY] #1142735
12/23/11 11:49 PM
12/23/11 11:49 PM
NY
NY
383man, I was surprised when Mancini told me it would not work. Will the Ati bolt right up with the stock pulley and will the alignment line up?
Re: Which Balancer [Re: Beep Beep] #1142736
12/24/11 12:32 AM
12/24/11 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I know that ATI does make one that mounts a mopar
pulley but dont know if it lines up correctly...
you would be best calling ATI for that info... I
make my own pulleys so I make it line up... I have
to build a new one next week for my SB because I moved
my alt .465 forward
Re: Which Balancer [Re: MR_P_BODY] #1142737
12/24/11 12:34 AM
12/24/11 12:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
No the ATI does not line up right. The belts will not line up right without shimming. Thats one reason I tried the Pro Sport as it said SFI and it has worked fine on my car. Course I only race a few times a year. Ron
Re: Which Balancer [Re: 383man] #1142738
12/24/11 12:37 AM
12/24/11 12:37 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is a pic of it on the eng. Dont know why they told you that as I asked when I bought it and they told me everything will line up. Ron
