Re: w9 cnc heads
[Re: W5DART66]
#1140602
12/21/11 12:11 PM
12/21/11 12:11 PM
Posts: 1,784 PA
W5DART66
PA
Re: w9 cnc heads
[Re: W5DART66]
#1140604
12/21/11 01:08 PM
12/21/11 01:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks good... I have a set of Chapman CNCd W-9s on my engine... I needed to clean up the transition lines in mine... they were pretty course
Re: w9 cnc heads
[Re: MR_P_BODY]
#1140605
12/21/11 02:10 PM
12/21/11 02:10 PM
Posts: 1,784 PA
W5DART66
PA
This was as cast head getting ready for Digitizing.
Re: w9 cnc heads
[Re: W5DART66]
#1140609
12/21/11 11:13 PM
12/21/11 11:13 PM
MR_P_BODY
Yeah I knew what your doing... looking good for your base for the digitizing
Re: w9 cnc heads
[Re: Evil Spirit]
#1140611
12/22/11 01:40 AM
12/22/11 01:40 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Make sense, sounds good. When I was putting my 472 together, during the mock up I put the heads on and then scribe the head to the block. This takes care of the core shift problems. Just my Keep us posted on the build, looking good!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: w9 cnc heads
[Re: Otherlane]
#1140613
01/24/12 09:55 PM
01/24/12 09:55 PM
Posts: 1,784 PA
W5DART66
PA
Flow on the intake port should be close to this as its getting same intake port as the W8 I did. I hope to have 2 sets of the W9s done next week flow #s 0.4000 276.3 0.4500 303.2 0.5000 328.6 0.5500 350.4 0.6000 367.5 0.6500 377.6 0.7000 382.3 0.7500 389.4 0.8000 394.3 0.8500 399.0 0.9000 402.8 This is at 28" of water port is nice and smooth.
Re: w9 cnc heads
[Re: W5DART66]
#1140614
01/24/12 10:42 PM
01/24/12 10:42 PM
Posts: 1,325 Orlando Fl
Dos Snails
Orlando Fl
are they paper thin at that size? it's about time for me to start working on my w 9 engine again . it will be boosted so I'm not sure that will need them large though lol
Re: w9 cnc heads
[Re: Dos Snails]
#1140615
01/24/12 11:09 PM
01/24/12 11:09 PM
Posts: 1,784 PA
W5DART66
PA
Not that thin but whats nice about having program on file for this head now is we can do just what you are saying. I can add .020" to the entire intake program.
Re: w9 cnc heads
[Re: W5DART66]
#1140619
01/25/12 07:24 PM
01/25/12 07:24 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
What size are the valves you are using?
Re: w9 cnc heads
[Re: Leon441]
#1140620
01/25/12 07:35 PM
01/25/12 07:35 PM
Posts: 1,784 PA
W5DART66
PA
2.180 intake 1.600 exhaust
Re: w9 cnc heads
[Re: W5DART66]
#1140622
01/25/12 09:27 PM
01/25/12 09:27 PM
Posts: 458 Michigan
BPE
Here is master for CNC chamber and export on W9 heads I am working on.
Pretty nice looking.....Reminds me of one I saw back in 1984.
Re: w9 cnc heads
[Re: W5DART66]
#1140623
01/25/12 09:41 PM
01/25/12 09:41 PM
Posts: 3,395 Pa
Hot 340
Pa
Are you CNC'ing these with the seats left in place?
Re: w9 cnc heads
[Re: Hot 340]
#1140625
01/25/12 10:35 PM
01/25/12 10:35 PM
Posts: 1,784 PA
W5DART66
PA
yes its best to cut with seats and guides in the head then size guides and cut seats.
Re: w9 cnc heads
[Re: W5DART66]
#1140626
01/26/12 04:18 AM
01/26/12 04:18 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
could you use these heads in a turbo or procharged application? 48* block
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
Re: w9 cnc heads
[Re: Biginchmopar]
#1140631
02/05/12 01:00 AM
02/05/12 01:00 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Lookin' good Brett. Now we need to build a nice 450cid ritter block build!!
Brian Hafliger
Re: w9 cnc heads
[Re: W5DART66]
#1140633
02/09/12 02:07 PM
02/09/12 02:07 PM
Posts: 1,784 PA
W5DART66
PA
Re: w9 cnc heads
[Re: W5DART66]
#1140634
02/09/12 02:07 PM
02/09/12 02:07 PM
Posts: 1,784 PA
W5DART66
PA
Re: w9 cnc heads
[Re: Brian Hafliger]
#1140636
02/09/12 02:39 PM
02/09/12 02:39 PM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Agreed! I know of a 48 degree 468ci.that could use a set
-Kenny
Re: w9 cnc heads
[Re: W5DART66]
#1140639
02/10/12 09:40 AM
02/10/12 09:40 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
What is the CSA of the intake port and volume?Thanks Brett Looks good.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
Re: w9 cnc heads
[Re: 440W8 Duster]
#1140640
02/10/12 11:34 AM
02/10/12 11:34 AM
Posts: 1,784 PA
W5DART66
PA
Just over 3in at flange.
Re: w9 cnc heads
[Re: W5DART66]
#1140641
02/10/12 12:32 PM
02/10/12 12:32 PM
Leon441
Lynchburg, VA
My CFE w8's had a sleeve where the head stud area was broken through. They also used a 7/16 head stud instead of the 1/2". Was told the sleeve was to strengthen the head so the head stud when torqued down would not crack the head. Probaly less chance of cracking the head with the less torque the 7/16 bolts require to stretch the stud.
Leon
Re: w9 cnc heads
[Re: Otherlane]
#1140648
02/15/12 03:26 AM
02/15/12 03:26 AM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
Man that is real good! Do ever work on Big Blocks? I just bought a set of W9's and with those kind of numbers you could make some serious power. I was going to build a 440 small block, I might have to rethink that and go a bit bigger. I would really like to get those kind of number out of a set of B1-BS heads.
Re: w9 cnc heads
[Re: W5DART66]
#1140654
02/15/12 01:41 PM
02/15/12 01:41 PM
Posts: 1,784 PA
W5DART66
PA
Re: w9 cnc heads
[Re: W5DART66]
#1140655
02/15/12 01:42 PM
02/15/12 01:42 PM
Posts: 1,784 PA
W5DART66
PA
Re: w9 cnc heads
[Re: sshemi]
#1140658
02/15/12 08:53 PM
02/15/12 08:53 PM
Posts: 1,784 PA
W5DART66
PA
How many cc intake runner?
Will have to cc one should be about 290cc to 300cc
Re: w9 cnc heads
[Re: Biginchmopar]
#1140663
02/15/12 11:47 PM
02/15/12 11:47 PM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
B1-BS head doesn't have a tall enough port for that kind of flow. Only so much you can do with a standard port height. Better capability with the Victor head or the Indy EZ due to the raised port. It would be nice though, standard height intake port and that kind of flow? It'd surprise the crap out of folks.
Re: w9 cnc heads
[Re: Biginchmopar]
#1140666
02/19/12 02:56 AM
02/19/12 02:56 AM
Posts: 243 United States
W9 Dart
United States
J,
If you had any tallent we could get 380 out of a set of B1-BS's.
p.s. another very quick street car is going to rumbling around the Carson area this summer. W9 440 in an A-body
Is that 440 block a 59* lifter bank angle block? I ask b/c I have a set of fully ported W9's for my R1 block but the 59* block with it's 1.875 lifter bore spacing makes me nervous with the push rod angle.. I know I can run the offset rocker but the little 5/16 push rods is less than desirable for my boosted application.
Re: w9 cnc heads
[Re: W5DART66]
#1140669
02/28/12 02:06 AM
02/28/12 02:06 AM
Posts: 1,784 PA
W5DART66
PA
Re: w9 cnc heads
[Re: Otherlane]
#1140671
02/28/12 11:32 AM
02/28/12 11:32 AM
Posts: 1,784 PA
W5DART66
PA
How you think the 9s compare to the 8s that you have worked on? just asking because there is always a talk about which will make more power and w9 cant make big power.
So far I think W9s have not been given fare shake I think they will make good power but most of the W9 stuff was for dirt track ports and chamber all wrong. I did not like the W9 for same reason but now that I have worked with them they are nice, Intake port has more meat in it than early W8s. Draw back is the valve are .100" closer to exhaust side of head.(this will hurt small bore more and small bore with big lift .750"plus will be at disadvantage) I think if you are doing W9 engine you should run 4.150 bore or bigger then valve placement would be a wash. The other thing I am updating 3 sets of W8s right now and they are all a PITA start with new W9s and dont look back. I think my W9 in max effort NA deal can do 850~900HP to be seen but the data on the head backs this up now just need some one to step up and build one.
