Page 3 of 4 1 2 3 4
Re: w9 cnc heads [Re: W5DART66] #1140641
02/10/12 12:32 PM
02/10/12 12:32 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My CFE w8's had a sleeve where the head stud area was broken through. They also used a 7/16 head stud instead of the 1/2". Was told the sleeve was to strengthen the head so the head stud when torqued down would not crack the head. Probaly less chance of cracking the head with the less torque the 7/16 bolts require to stretch the stud.
Leon
Re: w9 cnc heads [Re: Leon441] #1140642
02/10/12 01:35 PM
02/10/12 01:35 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I would put a sleeve in it just for the crush reason. I have done it on other heads and it works good.
Re: w9 cnc heads [Re: Biginchmopar] #1140643
02/10/12 01:37 PM
02/10/12 01:37 PM
Carson City, Nevada
Carson City, Nevada
The heads look real good and I'm intesested in having a set of W9's done.
Do you have any idea what the CnC charge will be?
PM me if need be.
Re: w9 cnc heads [Re: Biginchmopar] #1140644
02/10/12 08:18 PM
02/10/12 08:18 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
So whats your output on the w9 heads? Well the performace be right up there with the 8s
Re: w9 cnc heads [Re: Otherlane] #1140645
02/14/12 03:04 AM
02/14/12 03:04 AM
Carson City, Nevada
Carson City, Nevada
Have you had a chance to do a valve job and flow a couple ports?
Re: w9 cnc heads [Re: Biginchmopar] #1140646
02/14/12 11:47 PM
02/14/12 11:47 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
0.2000 147.6
0.2500 174.9
0.3000 192.2
0.3500 218.2
0.4000 247.6
0.4500 277.2
0.5000 304.5
0.5500 331.5
0.6000 351.5
0.6500 369.0
0.7000 384.9
0.7500 392.6
0.8000 399.1
0.8500 402.8
0.9000 403.8
This is the #s right now(Right out of CNC) .Valve job no blend into chamber/light blend into bowl.
Lower lift/mid lift numbers will get better hate to put the numbers up but don't know when I will have time this week to do rest of the blend work and get them back on the flow bench.
The port takes off .600" up and the sound is sweet.
Re: w9 cnc heads [Re: W5DART66] #1140647
02/15/12 12:25 AM
02/15/12 12:25 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
700 lift and above the W9s are better than the 8s.i guess i cant go wrong with the new 9s i bought new for $600 shipped,bare of course
Re: w9 cnc heads [Re: Otherlane] #1140648
02/15/12 03:26 AM
02/15/12 03:26 AM
Carson City, Nevada
Carson City, Nevada
Man that is real good!
Do ever work on Big Blocks?
I just bought a set of W9's and with those kind of numbers you could make some serious power. I was going to build a 440 small block, I might have to rethink that and go a bit bigger.
I would really like to get those kind of number out of a set of B1-BS heads.
Re: w9 cnc heads [Re: Biginchmopar] #1140649
02/15/12 09:27 AM
02/15/12 09:27 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
So a w8 and 9 should be pretty much close on power with the flow numbers on the 9s?
Re: w9 cnc heads [Re: Otherlane] #1140650
02/15/12 09:50 AM
02/15/12 09:50 AM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
I dont see any reason it should not.
Most of the W9s that are CNC were Dirt track stuff not the best ports or chamber for GAS drag car.
This set up is for drag car/fast street car. The W9 is much nicer than I thought going into this deal vs W8 early castings.
The W9 is light but it has Material in the right spots for nice intake and exhaust ports. We did pressure check this set of heads at 100psi no leaks.
Re: w9 cnc heads [Re: W5DART66] #1140651
02/15/12 11:21 AM
02/15/12 11:21 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i think what ur doing is great,especially with all the w9 stuff out there hope all the effort pays off for you,i think it will.
Re: w9 cnc heads [Re: fishy340] #1140652
02/15/12 01:25 PM
02/15/12 01:25 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
100 psi with no leaks, sounds like a boost friendly head.
Re: w9 cnc heads [Re: Dave W] #1140653
02/15/12 01:39 PM
02/15/12 01:39 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
3rd set of W8s out of the cnc
Rolled 1.5* 36cc chamber
Re: w9 cnc heads [Re: W5DART66] #1140654
02/15/12 01:41 PM
02/15/12 01:41 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Sm chamber W8
Re: w9 cnc heads [Re: W5DART66] #1140655
02/15/12 01:42 PM
02/15/12 01:42 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
One more
Re: w9 cnc heads [Re: W5DART66] #1140656
02/15/12 03:39 PM
02/15/12 03:39 PM
sweden
sshemi Offline
sshemi  Offline
sweden
How many cc intake runner?
Re: w9 cnc heads [Re: sshemi] #1140657
02/15/12 03:57 PM
02/15/12 03:57 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
How much does the exhaust flow?
Re: w9 cnc heads [Re: sshemi] #1140658
02/15/12 08:53 PM
02/15/12 08:53 PM
PA
W5DART66 Offline OP
W5DART66  Offline OP
PA
Will have to cc one should be about 290cc to 300cc
Re: w9 cnc heads [Re: W5DART66] #1140659
02/15/12 10:04 PM
02/15/12 10:04 PM
Glendale, AZ
Dave W Offline
Dave W  Offline
Glendale, AZ
Brett, sent you a pm.
Re: w9 cnc heads [Re: Dave W] #1140660
02/15/12 10:58 PM
02/15/12 10:58 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
So would you do a uncut w8 head for the same price or does the extra materal cost more? Just throwing it out there....
Page 3 of 4 1 2 3 4
