Page 3 of 3 1 2 3
Re: Six-Pac Stroker. Info for Set-Up Needed. Jetting et [Re: jbc426] #113904
09/05/08 05:04 PM
09/05/08 05:04 PM
USA
Rollin Hand Offline
Rollin Hand  Offline
USA
Is that Inovator Gas Analizer sold by Billy Mays.
Re: Six-Pac Stroker. Info for Set-Up Needed. Jetting etc: [Re: Big-Mike] #113905
09/05/08 07:48 PM
09/05/08 07:48 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
We've run two 500 cu in engines w/ the six pac set-ups both a little under 600hp. One used 69 center w/87s outboard, the other 66 center and low 80's ouboard.
I would guess that if you used 64s and 84s you're not to far off, and the not pulling past 6000 might be from something other than jetting.
Re: Six-Pac Stroker. Info for Set-Up Needed. Jetting etc: [Re: BSB67] #113906
09/06/08 06:12 AM
09/06/08 06:12 AM
New Zealand
Big-Mike Offline OP
Big-Mike  Offline OP
New Zealand
Right! 1st one, the Analizer,have'nt a clue;but it is instant & broard in readings.
The Hughes Engine site column; funny, i just come to here from reading that very item. [Edited by Moparts - Keep it clean]! does that mean i have to send my manifold all the way there & back.
BBS67, thanks for the coments there. I have all Brand-New Six-Pac,so i guess i better go a huntin!
I may just bite the bullitt & get 1 of Hughes Manifolds as the cost versus the next 20 yrs i hope to still have the car tells me to forget cost & just get whatever it takes to make some serious grunt, but still streetable.
Thanks Guys!
Mike.
Re: Six-Pac Stroker. Info for Set-Up Needed. Jetting etc: [Re: Big-Mike] #113907
09/07/08 01:44 PM
09/07/08 01:44 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I just pulled #7 and #8 plug since those were the easy ones. I am running rich. I have 78 on the passenger side and 83 on the drivers side. What number should I go with? I am using NGK-BCP6ES plugs gapped to .45. It is timed at 14 initial and 35 total. I am running aluminum manifold with blocked heat cross over.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Page 3 of 3 1 2 3
