Re: ? for the Stick guys only..
[Re: 5126brl No more]
#1137792
12/17/11 06:42 PM
12/17/11 06:42 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
bout 6200, i know the shift light comes on (6100) but either I don't remember or don't see it. Just getting old I guess. 28 x 9 tires
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: rollerfork]
#1137798
12/17/11 06:59 PM
12/17/11 06:59 PM
Posts: 1,946 Connecticut
5126brl No more
Connecticut
I run a hoosier 29x9 slick Dana 4.10 gear 4-speed. Go threw at 6300 at 130 mph.
Great looking car... Love the slicks With Armoral
[Re: rollerfork]
#1137800
12/17/11 08:02 PM
12/17/11 08:02 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
i was going through about 7,000 @ 130, at the same track its about 1 mph slower with an automatic 4.56 gear 29in tire. if it were a wedge i wouldn't be twisting it quite as hard. http://youtu.be/HSUrUBZogDs
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: JD Dart]
#1137804
12/18/11 07:53 AM
12/18/11 07:53 AM
Posts: 1,259 Netherlands
72Challenger
Netherlands
4.56 gears w/ 33" tires crossing the line at about 6700-6800 running 8.9's. Switching to 4.88 gears next season.
#1137808
12/18/11 02:22 PM
12/18/11 02:22 PM
Posts: 151 ohio
Rich970
ohio
I am trying to see what rpm you are going thru the traps at and with what Gears and tire size.
I am trying to get some more rpm at the top end and do not want to swap out my 4.10's
right now I'm at 5400 with 29" street tires. And when i compare to my friends with autos I see alot of convertor slip.
Can i ask what rpm you leave and shift at, what trans , ?
#1137809
12/18/11 02:40 PM
12/18/11 02:40 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
With my Richmond 5-speed I trap in fourth gear(1.24)fifth gear is direct 1 to 1. I run 3.54 gears,28" slick,6600 RPM,125.6 MPH Now when I was running a 4-gear I ran 4.56 gears and would trap at just over 6300 with 28"slicks. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
