Page 4 of 8 1 2 3 4 5 6 7 8
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 340SHORTY] #1135464
12/17/11 12:49 AM
12/17/11 12:49 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
YES... the 4.5 axles will interchange with your 5.5 axles.
if you were closer I have a set of rotors and even a nice set of wheels that would fit.
Id be interested in the fender and door mouldings.. the shortbox moulding wont work on my long box Dually..
I doubt I'll stip the moulding off if it leaves big holes to wled up underneath it
I'll have to see where we end up , body shop ,etc
I might even sell if before any of that happens
but, I'll look for more moulding in junk yards around here, they do show up at one yard often and if they do, the price is always fair
Thanks for all of your help & advice
stay tuned
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135465
12/17/11 12:53 AM
12/17/11 12:53 AM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
Wow
Guess you never seen the 70 ??
That thing is awesome! If you want an older square body, I'll swap you.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: Nirvana] #1135466
12/17/11 12:53 AM
12/17/11 12:53 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Man that thing is gorgeous!
Thanks, yeah, its been in magazines I built that about 2004/05 I guess
It does not get out much, its a 440 and wins best of show anywhere / everywhere I take it
funny, the resto guys hate me
I am kinda trying to sell it and build something else
I doubt anyone will step up, but --never know
https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135467
12/17/11 01:41 AM
12/17/11 01:41 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I have 4 Pick-N-Pull type yards around here & there's a member here that has that perfect trim piece I bet. I bought a nearly new/NOS grille & shell with an unstained part# as well the rest of the nearly new trim off a truck that had been hit really hard in the bed side New clips & all for $63.00. The clock had 23K on it & it looked 23K I've passed up alot of nice trim for the square trucks No sense in hoarding you know.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135468
12/17/11 02:02 AM
12/17/11 02:02 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I could use a cherry pass side head light bezel, it has a couple small cracks if anyone has one
The rest is nice
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135469
12/17/11 02:31 AM
12/17/11 02:31 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I'd put a Swepty front bumper on the rear. If I remember right I used Swepty rear brackets when I done it on a 73 Shorty about 20 years ago or so. You can weld a plate to a piece of square tube & mount it on top of the frame. Bolt a spare tire winch to it & get rid of the ugly factory hang down under piece. I was a Swepty-72-80 only for 31 years before I actually took a liking to the 81-93 7 years ago. Bob
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135470
12/17/11 02:39 AM
12/17/11 02:39 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Crazy me ..
I prefer the 91-93 grill over the 86-90 grill
Heck , I like them all , the square bodys to me just were the last of the breed
30-40 years later , they will be icons , everyone hated my sweptline UNTIL it was done
Now .. well , its cool
( to me at least )
I like Dodge trucks of all era's
I'm crazy like that
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135471
12/17/11 03:30 AM
12/17/11 03:30 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Crazy me ..
( to me at least )
I'm crazy like that
Me too! Nice truck you just got there also.
Moparlee
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: Robbins] #1135472
12/17/11 03:38 AM
12/17/11 03:38 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I am that Pinkguy has not been here to talk to us
I guess he is too good for us half ton'ers !
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135473
12/17/11 09:31 AM
12/17/11 09:31 AM
Lehigh Acres, Florida
rickstershemi Offline
Nice find Daryl
Rickster
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135474
12/17/11 09:49 AM
12/17/11 09:49 AM
scratchnfotraction Offline
new headlight bezels are fair price from rockauto and tail lights
member thedodgeboys has stuff for them also,I got the full rubber set for mine
Allen had one roll pan left and he has some of those euro tail lights for them too.
the plastic piece for the trim are $$$$$$ when removed there are no holes per say but it will have a lot of the rivit/studs to be removed...in the lower corner of the cab,the trim piece does have a small hole were it bolts a clip to hold the trim on.
i shaved it all off of mine.
if the 8 3/8 10 bolt axle aka 8 1/4 does swap axles i have a set thats 5 on 4.5 if you want( is a complete rear axle 3.2? gear )
FYI.gear ratio will be stamped in the ring gear along with yr
i will look around for part #s for the rotors,i have the ticket somewhere when i got mine from autozone...50$ each
the gear indicater has a small box gizmo on the back of the gauge cluster that has a cable hook that hooks on a sloted arm on the colum.
its the first thing to go most times and if someone droped the colum loose and did not un-hook it it stretches it out of wack.
i will look at a few of the cluster I have and see if there is a good one if you need it
if you pull the heater control..very gently as the switch likes to break off of the rack.
I swaped all mine to 85 wire harness/colum and got rid of the turn sig dimmer and wiper stuff myself,it has problems when its beat to death...yours not so much probly.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135475
12/17/11 12:17 PM
12/17/11 12:17 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Ok...that's all I got in truck/van wheel knowledge! Right off hand, I'd say listen to Scratchinfotraction and forget the rest of us...lol. Well, maybe Mopar Jamie too.
Well, I guess the rest of us don't know anything & you're the judge! Can you disprove what I posted? I know that you can't. You're not only disrespectful to me but to everyone else who has posted a reply. This thread was made for a group of replies from more than just a select few of your choosing. W
Please , don't be upset with Jackie , we know each other and he is kinda messing with me
was not pointed at you, trust me
Sorry if you took it wrong ..
Daryl, I'm sorry if I took it wrong. I love your truck, it's a great canvas. I can't wait to get my Shortbed home. Bob
Bob....Daryl is right,and I was just being silly and messing with him. I'm quite sure that you, Scratchn, and plenty of others have forgotten more about trucks then I'll ever know. Sorry about the Wheaties....I'll be glad to send a new box.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135476
12/17/11 07:47 PM
12/17/11 07:47 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Nice Truck....Can't wait to see what you do to it
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: JDMopar] #1135477
12/17/11 08:28 PM
12/17/11 08:28 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Jackie, I'm cool. I reckon we need a fly off the handle too quick smiley for me. I've not done anything like that in a few years or more. I never hated the square body, they to me at the time they came out were copy cats of sorts & my favorite curves were now square. After I bought my 87 to keep 6 years ago or so it grew on me & now I turn my head when I see a nice one. Bob
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135478
12/17/11 09:15 PM
12/17/11 09:15 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Anyone want / need the bug deflector ?
Or, its going in the trash
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135479
12/17/11 10:38 PM
12/17/11 10:38 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Very nice truck! Did someone say silver?
Here is my '85 shorty. Original slant truck with OD 4, it now has a 318 in it with a cast OD-4 behind it. This was the motor and trans out of my '87 I wrecked.
When the original 8 1/4 kicked up (not welded right) I decided to run an 8 3/4 with 5 on 4.5 bolt pattern to utilize my 15x8 stock steel wheels. Mine is from a '72-'74 truck.
The axle is flipped and it decided to kick up on me today so I plan to get it welded soon. I have about 2 to 3 inches of clearance between housing and frame.
On the front I am going to go with '81-'84 rotors so I can have matching bolt pattern.
OK here is a pic. Dont get jealous because it is silver.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135480
12/18/11 12:10 AM
12/18/11 12:10 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It has been claimed by a Moparts member
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135481
12/18/11 04:29 AM
12/18/11 04:29 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If you do the flip her's how I do the e brake so it's not so low.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135482
12/18/11 07:54 AM
12/18/11 07:54 AM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
l need one of those brackets! l'll trade even for a bug deflector l took off of mlne!
1981 Dodge D150 360 auto
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135483
12/18/11 02:18 PM
12/18/11 02:18 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The bearing diameter O.D. changed not the I.D. if I remember correctly I've always put an 83/4 in an not messed with either one anyway. I can't say that I'm right all the time for I am not a higher being. I don't claim to be & do not proclaim nor do I judge any of you. BOB
According to the bearing specs on Rockauto the inside diameter changed aswell
