warped Thermoquad #1134016
12/14/11 06:03 PM
12/14/11 06:03 PM
Hangtowner Offline OP
Is there any harm in truing up the top of the plastic float bowl by .010 to .020 using a milling machine? Since the float measurements are from the lid, I figure that stays the same and I can lower the notch for the plate that goes across the secondary an amount equal to what I take off with the milling machine.
Re: warped Thermoquad [Re: Hangtowner] #1134017
12/14/11 06:09 PM
12/14/11 06:09 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
How would this be achieved without it turning into dust? I have used a plate of glass and 800 sand paper, or a machinist block, something flat.
Kasey
Re: warped Thermoquad [Re: Hangtowner] #1134018
12/14/11 06:14 PM
12/14/11 06:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You could mill it but the sand paper and flat surface
is just as good and usually faster.... I did many
with the sand paper on a sheet of glass(mirror)
Re: warped Thermoquad [Re: Hangtowner] #1134019
12/14/11 06:30 PM
12/14/11 06:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is this measurement taken with it bolted to the base ?
Re: warped Thermoquad [Re: JohnRR] #1134020
12/14/11 11:59 PM
12/14/11 11:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Someone said something naughty
I wonder who it beez ...
