Spark plug choice for HEMI #1130771
12/09/11 08:46 PM
12/09/11 08:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
477
alum heads
10,5:1 compression
solid flat tappet camshaft
its a street engine.
Which spark plugs should I use?
Re: Spark plug choice for HEMI [Re: domingo] #1130772
12/09/11 10:53 PM
12/09/11 10:53 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What heads? we need to know aht heads you are running, some heads need a different reach plug than others...
I love the AR series plugs from AutoLite. You cant foul them... I run them om alky for two seasons, change them, cause I think they need changed. I know guys changing plugs like I do under wear. I dont know why..
Anyways...
My MP Aluminum Hemi heads (edelbrock castings)
I use the AR 3933 which is a bit cold for that mild of compression, but I was running 14:1 so...
AR 3934 I run with a large wedge with Moderate 12:1 compression...
These plugs are cheap, and I can get them at the local Advance Auto in town, for about $25 a set of 8...
Re: Spark plug choice for HEMI [Re: Bob_Coomer] #1130773
12/09/11 11:13 PM
12/09/11 11:13 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Anyways...
My heads are the newer MP edlebrock aluminum castings.
Re: Spark plug choice for HEMI [Re: domingo] #1130774
12/10/11 01:26 AM
12/10/11 01:26 AM
I like to use the AR3911 or the Champion RC9YC for a street motor on pump gas with similar compression on a aluminum headed wedge or Hemiroid
Re: Spark plug choice for HEMI [Re: Cab_Burge] #1130775
12/10/11 11:48 AM
12/10/11 11:48 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks cab!
