Re: NEW arp moly lube questions.................
[Re: rickraw]
#1130257
12/09/11 12:03 AM
12/09/11 12:03 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
That`s where I`m at now and was told the same thing about re-torquing although I`ve never done it and have had zero issues/failures. Thankxxx........... So when you re-torque em do you start from scratch or back em off and go straight to 70 ft. lbs.?
[Re: rickraw]
#1130259
12/09/11 12:44 AM
12/09/11 12:44 AM
Posts: 43,119 Bend,OR USA
Cab_Burge
I think Thumpers question is about the new ARP Ultra lube in the blue paks versus the older ARP dark grey moly lube in the white paks. I have heard that the new ARP Ultra lube has issues duplicating the same stretch on fasteners with the same torque when done on back to back testing Any one else heard or seen this?
[Re: challengermike]
#1130262
12/09/11 02:07 AM
12/09/11 02:07 AM
Posts: 4,673 On the parachute mount
n20mstr
what head gasket are you using??
I have never re-tourqed a head. I have used Fel Pro and Cometic gaskets. I use ARP lube and go in three steps 30, then 50 then 65 ( alum block and heads) then i prob re check about 5 times...LOL
....BAD A$$ STREET CAR.....
