Re: New 588 blown hemi build.
[Re: camastomcat]
#1129779
12/11/11 10:41 PM
12/11/11 10:41 PM
The guys that do this at truely competitive level like the smaller CI for the best reliable horsepower, like 500 CI. I never built one, but have worked on a few friends blown cars, and that's how they did it. I know first hand that big CI and blow by don't mix, and that's N/A.
This is not being built for competition racing, points chasing or ET chasing. Other than doing a pully change there will be no continuous mods and bla bla bla, when this motor is done that's it. I will be just going out and having a gay old time while I am still on this planet and after that I'll go fishing with the wife. You guys all need to take the competitive pro racing scenario out of the equation and not get your panties in a knot.
Well then......it sounds like you have it all figured out. You asked on the race only area, we gave opinions.....good luck.
If you re-read my OP you will not see any question marks just sharing of a build. Thanks for all the opinions though, it shows you all care.
[Re: ]
#1129780
12/12/11 01:00 PM
12/12/11 01:00 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
Mine is going to be around 500 to 512 with the KB water heads. Mine will be street driven a lot.Good luck on your 588 build.Keep us posted on cam specs and such!
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: ]
#1129781
12/12/11 04:41 PM
12/12/11 04:41 PM
Posts: 43,112 Bend,OR USA
Cab_Burge
I have built and dyno tested two 426 blower motors, one all aluminum KB street Hemi block, 499 C.I., 10.71 BDS blower with EFI and a new Mopar iron block that ended up being around 484 C.I., 4.25 bore with a old top fuel crank that was fully counter balanced with stock Mopar rod sizes that was 4.375 stroke with a Littlefield 10:71 street blower and two Holley 1050 dominator blower carbs. The iron block made 927 HP at 7300 RPM on CA pump gas with 7 lbs of boost Go with what you want, diffentitly the bigger 14:71 blower, but not a BDS one PM if you want with any other questions
[Re: Cab_Burge]
#1129784
12/13/11 01:53 PM
12/13/11 01:53 PM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
So Cab, what you're saying is, you "really" like all of the BDS stuff......
[Re: 23T Hemmee]
#1129785
12/13/11 02:03 PM
12/13/11 02:03 PM
Posts: 3,021 NY
B1duster
NY
[Re: 23T Hemmee]
#1129786
12/13/11 03:13 PM
12/13/11 03:13 PM
Cab_Burge
You know it is easier to make good decisions on parts when you know who the good and bad guys are I spent many days at the dyno with Craig Railbeck finding out that he was not one of the besst guys out there I'm sure his intentions where good but his results and parts where not Just another non enjoyable part of my life
[Re: hemi-itis]
#1129790
12/16/11 11:50 PM
12/16/11 11:50 PM
Well I locked in a set of stage v big valve heads from FHO today. Got a smoken deal on them that I just about missed out on. The heads were used for one dyno session to test new rockers Tim developed and have already been machined. They have titanium 2.4 intake valves and 1.90 titanium exhaust valves, light weight titanium retainers, a high dollar locking lash cap system, Nextec polished valve springs and the heads have been fully cnc'd and flow 500 plus. I will get the flow chart #s from Tim later. Right now the springs are good for 1" lift so those will get changed out for some that are good for .800" lift. Just as I'm writing this the door bell goes off and these just arrived.
[Re: BDS871Cuda]
#1129792
12/17/11 12:07 AM
12/17/11 12:07 AM
To you and a few others maybe But I'm with FHO on this one. Tim has laughed at the naysayers.
[Re: ]
#1129793
12/17/11 01:38 AM
12/17/11 01:38 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Heck, I could have made you a good deal on a set of those rods and a Callies crank... but its a 4.15 stroke... all new stuff
