440-6 Idle Solenoid Issue? #1127645
12/04/11 10:00 PM
12/04/11 10:00 PM
People's Republic of Kali
70runner Offline OP
70runner  Offline OP
Basically stock setup. Using a 12amp battery charger to activate the solenoid (pic) while I adjust the trans linkage and throttle cable (don’t have the battery in yet). The solenoid works fine until I attach the throttle rtn spring – can’t seem to overcome the spring tension. Using the repro 440-6 orange spring (70RR). What think ye?
Re: 440-6 Idle Solenoid Issue? [Re: 70runner] #1127646
12/04/11 10:14 PM
12/04/11 10:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I wouldn't use a "battery charger" to activate the solenoid, use some leads connected to a FULLY CHARGED battery to test the unit, before calling it toast,...what's the history on the selenoid?
Re: 440-6 Idle Solenoid Issue? [Re: 70runner] #1127647
12/04/11 10:15 PM
12/04/11 10:15 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
you realize you have to tip the throttle manually to get it to set right... it wont pop the throttle back on its own.. dan
Re: 440-6 Idle Solenoid Issue? [Re: DAYCLONA] #1127648
12/04/11 11:09 PM
12/04/11 11:09 PM
70runner Offline OP
70runner  Offline OP
Mike, I thought about that also. Solenoid is a Standard Motor part (forgot the pn) I've had for years. Just changed the plunger. Basically new.
Dan, not sure I follow. Pls elaborate.
Re: 440-6 Idle Solenoid Issue? [Re: 70runner] #1127649
12/04/11 11:24 PM
12/04/11 11:24 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The solenoid can't overcome the return spring pressure on it's own...You need to depress the gas pedal so the solenoid can set itself in the extended position then it will stay until it's deactivated...
Re: 440-6 Idle Solenoid Issue? [Re: ph23vo] #1127650
12/04/11 11:30 PM
12/04/11 11:30 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: 440-6 Idle Solenoid Issue? [Re: screamindriver] #1127651
12/05/11 01:23 AM
12/05/11 01:23 AM
70runner Offline OP
70runner  Offline OP
Got it...thx!
