i took the coronet out for drive today and noticed that the steering colomn gives a little, you can move it up and down, not a lot, just enough to notice. this is a used column and i did not replace the bearings at the time i installed it because everything look good.
i know there is a way to rebuild the column and put new bearings, however, i have never done it and do not feel comfortable doing it.
is there someone i can send my column just to have the bearings replaced, it does not need anything else.
